Question about LG L1920P 19" LCD Monitor
I need a Vista driver for a Flatron L1920P monitor
    Guru:
  • LG Master
  • 829 Answers
Hi Click the below link to download the driver
http://mrdriver.com/device.php?id=1293&show_devs=a
Posted on May 10, 2009
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
The power button on my lg flatron L1920p does not work or turns on the monitor; what can I do to fix the problem?
The monitor's power inverter also known as power supply probably needs to get replace, have a computer professional handle it.
Mar 08, 2011 | LG Flatron L1770HQ (Silver Monitor
Hi there I have an LG Flatron L1920P and it just went dead. CaNn you give me a few tips on what to look for? Thanks
First place to check will be the caps in the power supply section. Look for caps with leaking/bulging top.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Computers & Internet
Hooking up monitor
kingpin_392, I f date of manufacture is 2005 or 2006 unit may need to be refurbished. If a "known good" monitor functions ok with your pc and is cabable of displaying the WIN desktop screen, then you wil need to ask brother-inlaw if he had same "check signal cable" symptom. Try to find out how to to do source select on the unit. The monitor may be looking for signal at the DVI port instead of the VGA connector?? 12fixlouie
May 08, 2010 | LG L1920P 19" LCD Monitor
I need a driver for the LG Flatron L1919S LCD Monitor
for what purpose you want the driver for the monitor? generally there are no need to install the monitor driver.
Apr 01, 2010 | LG Flatron L1919S LCD Monitor
My flatron 1920P monitor is in power saving mode. How do I get it out of power saving mode?
It may stuck in the standby mode because it is not seeing the signal feeding it or there is problem in the power supply, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 29, 2009 | LG L1920P 19" LCD Monitor
Change the contrast on my LG screen FLATRON L1919S ?
see if there is some software cd with it or see if display properties has somthing in setup
Jul 29, 2009 | LG L1920P 19" LCD Monitor
Need driver compatible to vista or windows7 for the monitor
Hi friend,
You are right in time I will give you the addresses of two websites from where you can download drivers or in that case any software.
The sites are www.brothersoft.com and www.bitcomet.com. And the best thing in both these sites is they dont charge you anything.
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
May 14, 2009 | LG Flatron 776FM 17" CRT Monitor
LG L1920P flatron just flashes
Check the + 12 and + 5 Volt voltage coming off the power supply board. Look carefully as the +5 volts might be breathing.. meaning varying between +3.89 up to +5 and then cycles again.
Jan 04, 2009 | LG L1920P 19" LCD Monitor
LG L1920P 19" LCD Monitor Logo
770 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
