I have a True Freezer T-19F. It has been sitting for months, just turned it on yesterday. Very loud while running like a dryer would sound. Long cycle, may have went off twice yesterday. I ended up unplugging it because it seems as if it didnt want to shut off. temperature was set inside of refrigerator between 3-4. outside temp read 10F. Food did freeze but worried about the noise and the long running time
Http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
The above will take you to the installation manual for your unit. This is to make sure you have set up the unit to their specs.
There are multiple things that can cause a lack of cooling. Let's cover a few of them.
1: Make sure the condenser coil under the unit is clean. You have to be able to take a flashlight and see light through the coil and fins. Be sure unit is off when cleaning. Use vacuum, compressed air, or a long, stiff bristle brush and go with the fins direction so they do not bend over.
2: The termostat may be set wrong or is not working as designed. Look for the compressor and fan on the condenser to cycle off when temp is met and on when it gets too warm. If unit is running all the time, look for frozen up evap.
3: If evap is frozen up, no air can pass through so no cooling is taking place. Air can not go through a solid block of ice. Clear ice with warm water. Again, make sure unit is off first.
4: Door not sealing or closing all the way. Seal on door should have magnets that help seal them to the door frame.
5: Again, if unit is running all the time, as in #2 above, unit may be low on refrigerant (freon). If you suspect this to be the case, have a qualified tech do the repair. Make sure he locates and repairs the leak. Adding freon without the repair means he will be back to do it a second time. The system is a sealed one and you should not have to continually add freon.
Good Luck and hope this get you going.
