Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washer dryer error code 'check outlet pipe'
My washer dryer started saying check outlet pipe,i used to turn it off then try again and it worked,this time it said it and it stopped working so i checked outlet pipe and all was ok.Now my washer/dryer leaks,the seal looks slacker then it did,is it broken and need a new seal or could it be something else.
  • 1 more comment
  • chewi Nov 12, 2007
    my machine door and wash lights up, but the water dosn't come in machine,then there's a funny letter's or number's, don't no how to explain, cause don't have manual.
    can you help pls.
    melinda
  • Anonymous Dec 09, 2007
    f-01
  • Anonymous Mar 17, 2009
    I had the exact same problem, but i managed to fix it (for now) by giving it a different error to play with - unplug the motor and start the machine, then cancell the error and plug the motor back in..
    Thats hopefully got me a few more washes out of a very knackered machine ;)
    Champion:
  • 249 Answers
The outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Posted on Nov 28, 2007
SOURCE:
LE code error
Just try resetting the unit it by disconnecting from power outlet, remove plug for say five mins, and then try and run it again.
Failing this, Check for any obstructions in your drain pipe, if you can move the unit yourself to check at the back of it, but assuming you might not be able to run these checks on your own, best to have a tech come do it for you
Feb 02, 2018 | Washing Machines
Dryer heating but cloths not drying
Hi Is good you start from wright leg Is probably limit sensor (not expensive) and next program board (is expensive). No error codes?? Check also outlet at wall where is connected vent pipe. Good luck.
Oct 19, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
Displaying error 20
E20 is a drain problem.
Most likely is is blocked, so a good clean out is needed.
(turn off water and unplug) Pull out the machine, take outlet hose out, and clear drainpipe with a drain cleaner - then rinse through.
Clean outside of pipe, and check inside condition.
Replace & reconnect.
Try 2 cups of washing soda in the machine and do 2 hot washes to try and flush blocks through.
If this does not improve matters, you may have to strip the machine to clear the pump and outlet pipe manually.
Aug 20, 2009 | Frigidaire Affinity ATF6000F Front Load...
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
WILL NOT SPIN ON HIGH
The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
137 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
