Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook I have a problem installing OS X 10.5.4. after the DVD is loaded, there a message on the screen saying " OS X cannot be install", what do I need to do?
  • verb75 May 11, 2010
    Are you using the system disks that came with the machine?
    Every machine comes with disks, but they are machine specific. For example: The disks that came with my MacBook will not work with yours.
  • Apple Master
  • 4,338 Answers
I just ran into this issue.
The problem stems from the CD not seeing the SATA hard drive. I called Apple and they sent me a new Mac OS DVD. Hopefully you have the Apple Care or they will charge you for the DVD.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 18, 2009
Macbook screen
well first of all ur mac ox is corrupted and for that make sure u have d mac os x os availave
first insert ur mac os x dvd in dvd ram and then power on ur macbook and then suddenly press command and c key in ur mac keyboard after that mac utlity appears then choose utlity option and then select repair disk and now re install ur os
Nov 29, 2013 | Apple aluminum 13-inch MacBook laptop-...
2010 13" Macbook pro will do is screen saying "Enter your system lock PIN code to unlock this Mac
The Mac is locked and has it say you need a code to open, so if you know the person who gift you the Mac ask for the code if no the only remedy is to re-load the system but you will need the the copy of the O.S.
Mar 22, 2013 | Apple MacBook Pro Notebook
Can't open Excel files after installing OS X 10.8 Mountain Lion on my Mac. HELP PLEASE!
Try repairing disk permissions by running the Disk Utility application until you get no errors (then restarting).
Hope by doing that you get the solution.
Aug 09, 2012 | Apple OS X 10.8 Mountain Lion
Flashing "?" when starting macbook..i
Can you be clear on the question:- 1>How did you try to Install disk start up. 2> is your harddisk been shown on Disk utility 3> are you using the right media for the same.
Sep 20, 2011 | Apple eMac G4 Desktop
My 17 inch macbook pro would not boot up to the login page, so I reset the SMC and got the login window to come up. Now I've tried logging in with my correct password and it appears to be going to the...
This is a pretty unusual problem but it should be easy enough to fix. If you're getting the login screen after logging in and it keeps doing the same thing without any prompt from you, there's a problem with the login kernel of the OS itself.
I'd recommend booting to the install DVD (Mac OS X Install DVD) - do this by inserting it and restarting by holding down the 'C' key until you see the Apple logo and spinning gear.
After choosing your language, on the next screen go to the Utilities menu in the upper left, choose Disk Utility, choose 'Mac HD' on the left and click 'Repair Disk.' There will also be 'Repair Disk Permission,' IGNORE IT.
Ostensibly it should find and repair the problem. To restart, go to Mac OS X Installer > Quit Mac OS X Installer and choose restart.
If the problem persists, boot to the install DVD again and reinstall - it will not mess with any of your documents, movies, music, or other personal documents. Basically just keep hitting next/agree/continue until it says it is installing, which will take 30-45 minutes.
Jan 13, 2011 | Apple aluminum 13-inch MacBook laptop-...
I have a macbook OS X, i boot up on windows xp then i notice that theres only 10% remaining on the harddisk intended to windows, then suddenly the blue color appear and says that i must shutdown the unit....
Your hard drive is corrupted and the OS needs to be re-installed on the hard drive. Re-install the OS using your discs, but first use disk 1 to go into disk utilities and select your hard drive, then click repair disk permissions. After that click on repair disk and see if that don't help. If that don't help then your next step is to re-install the OS, because somewhere the startup file got corrupted. If that don't work, then your SOL, which means your hard drive has given up the ghost and you need to install a new hard drive.
Sep 29, 2010 | Apple MacBook Mac Notebook
My macbook shows a white screen and a sound only and after that nothing happens
JUST TRY TO FOLLOW THE STEPS IT WILL BE VERY HELPFUL
Many computer shoppers choose to buy a Mac not only to use OS X, but Windows as well. That is one strong advantage that Macs have in the Mac vs PC war. Apple computers are capable of running Windows, either through Bootcamp or virtual machines.
So, why aren't Windows PC's capable of running OS X? Well, Windows PC's are capable of running OS X. But, it is against Apple's licensing agreement to do so. Thus, this article is intended for educational and demonstration purposes only. If you want to run OS X the best way possible, get a Mac.
*In order for this to work, your computer must have a processor that supports virtualization. If it does not, you may receive errors. For the most part, any newer processor lines: Core 2 Duo, Quad Core, and Core i7 should all work fine.
But, don't expect to not get errors if you are using an older Pentium 4 machine. The processor must be Intel and not AMD*
Because we will be installing OS X on top of Windows through a virtual machine, the first step is to get some virtual machine software. For this demo, we will be using VMware's Workstation 7.
If you do not feel like purchasing Workstation 7 at this time, you can get a limited trial here. The download may take a good half an hour to complete. Workstation is a 512MB file.
Upon download, go ahead and install Workstation 7 onto your computer. The installation process is very simple just launch the installer, and the VMware installer will guide you through the rest.
One thing to note, when it asks your if you want to do a custom install or a typical install, choose typical install. After the installer finishes, restart your computer
Now that you have Workstation 7 installed, you need a pre-configured VMware virtual machine file to install Snow Leopard on top of. Download this file (alt download) and save it to your desktop.
After you have the pre-configured virtual machine file downloaded, you will need to extract the files using WinRAR or another archive utility. If you do not have an archive utility, you can get WinRAR here.
Note: This file is just a disk image framework, no viruses or anything like that. VMware Workstation uses the disk image format to save and contain virtual machines.
Time to start installing Snow Leopard. Launch VMware Workstation by using the path Start > All Programs > VMware > VMware Workstation. Open up the VMware disk image framework that you just downloaded and extracted.
Select File > Open. Navigate to your Snowy_VM folder, open it, open up the next folder that says "Mac OS X 10.6 Server (experimental).vmwarevm, and choose the 2KB file that is named Mac OS X Server 10.6 (experimental). Click the open button to load the virtual machine.
From the Mac OS X Server tab in the VMware Workstation window, click the edit virtual machine settings icon. You may adjust the hard drive size, memory, etc, to your liking.
Select CD/DVD (IDE) and under the Connection settings, select Use ISO Image File. Click the Browse button and navigate to the Darwin_Snow.iso which is located in your Snowy_VM folder. Click the Open button to select the virtual machine.
Now it's time to power on the virtual machine. Click the Power on this virtual machine option. As soon as the process starts, hold down the F8 key on your keyboard. You should be prompted with a boot menu screen.
If you have not done so already, insert your OS X Snow Leopard Install DVD into your computer's CD/DVD drive. So far, you have loaded a workable virtual machine and framework into VMware Workstation.
Now it's time to actually install Snow Leopard onto that virtual machine disk image. You should see some settings icons located at the bottom right portion of the VMware window. Right-click the icon that looks like a CD and choose settings from the pop up menu.
Go back into the boot screen and select the option C Boot from DVD. Press the F8 button on your keyboard for advanced options and type "-v" without the quotes and hit enter. Now, VMware Workstation should boot your Snow Leopard install disc. It may take a couple of minutes to load
That's all there is to it. You should now be at the normal Snow Leopard install screen. Click continue on the first screen that comes up. On the second screen, click the utilities option in the install window and select disk utility. Use disk utility to change the hard drive format type to OS X Extended (Journaled). Exit disk utility and let OS X install completely.
Upon install of Snow Leopard, your virtual machine will restart. After it restarts you will need to do a couple of things to get into Snow Leopard. Select CD/DVD options, like you did before, and use the Use ISO Image File option.
Sep 26, 2010 | Apple MacBook Mac Notebook
Cannot install OS X
When installing a system on the computer, you must have the original disks for the computer or a new OS X 10.5 Leopard if you meet the minimum specs.
Your Mac won't take a system higher than the one that came with it, unless it is a new 10.5 disk.
May 09, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
53 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
