I have a Hitachi AX M140 combo the Dab Radio does not power on any more it appears dead, the DVD refuses to work it the radio is plugged in but works if I unplug it The amp and MP3 seems to be working fine although not when the radio is plugged in with the rest. I do not seem to be the only one with this problem. i have unplugged and replugged the machine from mains a few times, it used to solve all problems before. i have also switched the various elements in the rack no luck. Any suggestions? Best Y
  • 14 more comments
  • yves552 May 09, 2009
    Hi
    This does not address the problem, I do not have batteries, what is this, a joke? It is not funny, please reply to the problem not somebody else... or is this a rip-off??
    Best
    Y
  • yves552 May 12, 2009
    When I disconnect the radio unit at the back from the rest and reconnect it for a flicker of a second some light appear on the digital screen, very briefly, but nothing special just a few bars, the rest works fine when the dab radio is disconnected
    yes it does
  • yves552 May 23, 2009
    I replied to Palaboy and then nothing no frayed wires Guru, and where is the fuse? inside what part? the Dab part? could not find fuse inside...
    Palaboy, I sent 3 photos I don't know if it worked... the first one is the combo with radio second from bottom, second is radio and amp third is radio and amp from back let me know if you got them or not
    hi, palaboy, finally got it right, here are the photos back and front
    now the front
    and the whole unit as it is sold
  • yves552 May 24, 2009
    as requested...pt1
    and mr palaboy pt2...
    I plugged it with the rest with the part circled in yellow unplugged and nothing happens stays dead the part number seems to be CN 4101 it seems to connect with the frame...
    as requested
  • yves552 May 26, 2009
    Palaboy Any suggestions?
  • yves552 May 31, 2009
    well palaboy, no more to say???
    well i thought i sent it but it obviously did not register the only part number i can see is D4102 and D4103
    thanx but where can i get a replacement?
  • 15,935 Answers
Please check the power supply fuse on the inside, and also check the main ribbon cable for cracked/frayed wires.
(2) most common failures of your device.
also CLICK HERE for your user manual in PDF Format.
Thanks!!
Posted on May 13, 2009
  • 5,807 Answers
So lets start with the combo with out the Dab Radio . can you hear nice music playing mp3 without connecting the Dab radio?
Posted on May 12, 2009
  • 8 more comments
  • Rommel Cana
    Rommel Cana May 23, 2009
    ok, we have to concentrate on your Dab radio. can you possibly have a photo
  • Rommel Cana
    so that i can encircle the thing you have to work on
  • Rommel Cana
    Rommel Cana May 24, 2009
    thanks for the great pics, just need to have some inside view image of the ppic of your Dab , tuner
  • Rommel Cana
    ill send an example pic which i want to see
  • Rommel Cana
    im sending back your pic, try to unplug the connector within the yellow circle, and want to know the part no within the green circle. and tell me what happens when that part in yellow circle is disconnected
  • Rommel Cana
    another favor can i have the pic of the board the other side? you may need to unsrew the two im seeing in line with the white connector. your trouble is here inside this board
  • Rommel Cana
    Rommel Cana May 26, 2009
    favor again the part no on the right yellow circle
  • Rommel Cana
    Rommel Cana May 31, 2009
    is the part number? or anything printed on the part i have encircled within the yellow circle?
  • Rommel Cana
    if the voltage reading of D4102 from point +A and +B is the same have it replaced
  • Rommel Cana
    Rommel Cana Jun 01, 2009
    look but do not buy yet, just make sure the voltage reading from negative with the negative sign and + to the positive sign are exactly the same, you might be reading a voltage of say 12v dc, only if that value is the same with the both + , you can order it have it replaced. you can set your multimeter at a range of 50v dc.if at point B say your reading is 20v and on point A is 5v no need to replace that component cause it might be working, after that point thats the deciding factor, where your trouble really lies, if its the same exceeding 9v on point A will damaged the embeded ic chip on the lower right portion of your last picture
    Brigadier General:
  • 3,917 Answers
Most manufacturers offer a battery powered option at this price point too, but don’t plan to take your radio on a major expedition. DAB radios are notoriously power hungry so will need a large stack of batteries – 6 x ‘C’ cells is not uncommon. These add significantly to the carrying weight for a picnic and battery life is not great – only a few hours at most.
Would suggest to review the battery again.
Thanks
Posted on May 09, 2009
  • e-Guru
    e-Guru May 09, 2009
    Appologies for mis-understanding your issue. No this is not a rip off. We are technicians fixing issues online for various customers for the past 6 to 7 years now with a strong money back policy.
    Working on your issue.
    Thanks
HITACHI AXM 140 SYSTEM
Try to reset the system.For reset procedure,click the link below :-----http://technoanswers.blogspot.com/2012/01/hitachi-ax-m140-system-display-keeps.html
---------This will help.Thanks.
Jan 27, 2012 | Audio Players & Recorders
Can a hitachi ax-m133 be upgraded to dab +
if the hitachi unit has a line in socket, you can plug an additional DAB tuner in to give you dab.
Sep 20, 2009 | Audio Players & Recorders
Can not tune in Dab radio on AX-M131U
If it's anything lioke my DAB radio there is a Tune button that you hold down for more than 5secs and it goes into 'Autotune' mode - so that after some time ,say 1min, all the available stations are tuned1
Hope this works for you .
Nov 19, 2008 | Audio Players & Recorders
Region free code for hitachi ax-m140
Visit Hitachi Online (www.hitachi.com)
Jun 25, 2008 | Hitachi Televison & Video
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
Humming from speakers
bad grounds wires usally will do this
Feb 10, 2008 | Audio Players & Recorders
716 people viewed this question
 Grubhead
Grubhead
