Question about Kenwood KDC-W6027 CD Player
Kenwood head unit not powering up help please.
Iv turned a little problem into a big problem....Each time i turned the ignition on my sound settings would reset ect, so i took my head unit out to see if the consent power supply wire was connected to it and realised it wasnt, after trying to find out which is the right wire to connect (i did this by useing trial and error method and connecting wires back up) now the head unit wont power up at all?? i know there is power going to the cd player it self, because when the head unit isnt attached the red security light flashes on the cd player. i think by connecting wrong wires together i have blown some fuse but i have checked the ones on the cd player and in fuse box in car has anyone any ideas please???????
    Problem Solver:
  • 18 Answers
Find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
Posted on May 27, 2009
My DEHp8400bh only connects to my htc evo4g sometimes and other times it reads no service. please help
I've found that I need to have my phone on with Bluetooth enabled before the head unit powers on (i.e.starting the car). If it's already started I just pop the faceplate and snap it back in to power cycle the head unit. At that point Bluetooth always connects properly.
Dec 07, 2012 | Pioneer Deh-p8400bh Cd/mp3/ Receiver W/...
I was attempting to take my head unit out, and i assumed i had to use removal keys and whilst trying to use them to remove the head unit i dropped one of the keys into the unit. i diddnt think this would...
remove the unit from power for about 15 min, that should clear the settings then plug it back in. if it still shows protect then there is a short in one of the power or ground wires.
Mar 08, 2011 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
KDC-4051UG Only comes "ON" with
Your head unit is now connected correctly. That is how it is intended to be installed. Unless it doesn't store the radio stations. In that case the power cables of the head unit (RED&YELLOW) are incorrectly connected, but not a big problem. hope that helps dreamsystems
Feb 06, 2011 | Kenwood Car Audio & Video
Memory erases everytime the ignition is turned
Be sure that the yellow wire from the cd player is connected to a +12 volt source. ONe god source is the orange wire from the cigarette lighter if the cigarette lighter is working fine. If not run a wire from the yellow wire of the cd player to the fuse block in one of the pins marked "bat". Good luck. Please rate.
May 26, 2010 | Kenwood KDC-319 CD Player
Why wont my personal setting save for my Kenwood KDC-X493 car CD reciever? This is my 2nd aftermarket cd reciever and just like the 1st one I'm still having this problem.
Make sure you have the +12VDC and the Ignition leads hooked up properly.
If your head unit is pulling is power off of the IGN lead, it will reset every time you turn your car off.
Dec 31, 2009 | Kenwood KDC-X493 Car CD/ MP3 Player
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
Very little sound
make sure all your gains are turned up to atleast half.
Check your head unit, make sure your low pass frequency for the RCA's amp is set to high or set to more than 0. Make sure you don't have your fader set toward the front of the vehicle or you won't get any bass, but the subwoofer will be pulling only what the head unit is sending to the amplifier.
if that doesn't work I would try another pair of patch cables.
Do you have another subwoofer you can swap out to test your subwoofer with?
I have a subwoofer that has something wrong with the coil itself. Has your amplifier blown any fuses? If so the subwoofer coil is bad.
Also make sure you have a solid ground for your amplifier.
Hope this helps!
Apr 22, 2009 | Jl Audio 13W7 Car Subwoofer
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Sony gtx 500 cd deck/ kenwood 8104d tuning
Set your HPF and LPF on the headunit to match the crossover on the kenwood amp.
I have the same amp, it's really not difficult to figure out. Try these settings, For the AMP: Bass Boost: 0 Crossover: 150 Level: 1
Now just go into the menu for your head unit and make sure you set the crossovers to 150 or whatever option you have, just make sure they match.
Simple.
Feb 27, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KDC-W6027 CD Player Logo
159 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
