Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Dvd inside the dvd-rom
My macbook doesnot eject the dvd. It make some noise but does not go out. what can i do for this became solve?
  • Anonymous May 10, 2009
    the problem continue
  • 52 Answers
This is why there is more dust in you dvd rom. or loose of the spring. so near the eject button on the dvd room there is small pin hole. did you see that. just insert the pin little bit you will find the lock the press the pin and move the pin up and down , right - left. i hope that your dvd room will eject. ok bye.
Posted on May 09, 2009
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
The rom is not opening for me to put a disc inside.
that means no power is getting to it or it doesnot read. try to go on start, computer, see if its appeard on the list of devices. If is there then on your mouse right click and click on Eject, and here must eject and the problem will be by the eject button but when is not on the list then your DVD Rom is bad. you might need replacement. thanx.
Nov 11, 2012 | Acer Aspire 4315-2490 Notebook
E Machines T3302. DVD will not eject. In hitting the eject button, or right clicking on e-drive for DVD, and clicking on "eject", it sounds like it is trying to eject, but it won't eject....
On the dvd rom drive sound slike it catching on something on the inside stoppin git from ejecting you will have to use a flat head screw driver poke it from the top and very gently pry it open while pushing the eject button as soon as it ejects you can then remove any cds inside it and you can remove the dvd rom drive bezel and close it if it opens and closes freely while this dvd rom bezel is off then the piece of plastic you took off it is slightly made wrong you can get these bezels cheap or by finding an old rom drive and removing that one to replace with yours. any additional questions please use the comment box below Kronoguy
Jun 29, 2011 | E-Machines Computers & Internet
My dvd doesnot come out, it got stuck in the laptop. any no screen display, it is DELL Vostro 1510
- if you can't remove the DVD inside, there is a small hole besides the eject button if your not using a slot tray DVDrom
- you can stick a hair pin or a small pointed object to manually eject the dvd inside
- hope this work
- after this update your system for disk drivers
Jun 07, 2011 | Dell Vostro 1510 Laptop
The disc will not eject from my apple mac? why?????? The eject symbol comes up but the cd stays inside? HELP?
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Mar 23, 2011 | Apple Customized 15" MacBook Pro Laptop...
How can i remove the dvd from my mac, it is stuck. macbook pro 17 inch
Hope this helps.
Sep 27, 2010 | Apple MacBook Pro 17-inch 2.4GHz Notebook
Dvd will not eject and noisy
To eject, put a staple on small orifice on the front.
Or, by the Explorer window, go to letter of DVD, and with right mouse button, click on "eject".
Have any disk inside? Maybe the disk have some problem to do the noise.
Sep 18, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hi, I m a new user of apple mac book, I m trying to insert a disk in my dvd rom but still i am not able to open my dvd player. Can u help me that how will be open the dvd rom in apple mac book? means any...
I would please like to tell you there is no button in MACBOOK to eject a tray as there is no tray.
You simply see a line on the right hand side of your laptop where you can insert a disc, u need to insert a disc into that part and when you insert it you will show you an icon on your desktop showing you the cd contents.
When you want to eject it keep in mind u need to click on the icon on your desktop and press the eject button or u can also use the keyboard and press the eject button, which will bring the disc out automatically.
Please do not worry try it, I'am sure it will work for you.
If there would be any problem and you need any help please do not hesitate to ask.
I'am also giving you a link to see the video of how to insert and eject the cd, please note this is the old model of the macbook, the only difference is that the drive is now located in the right hand side of the laptop, dont worry take a look.
http://www.youtube.com/watch?v=yWOQ-xlSKVE
Thank you.
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
MacBook Pro often will not recognize commercial DVDs
Go to MAC's website and see if there are any driver updates for your MACBOOK Pro.
Oct 25, 2009 | Apple Genuine Pioneer "SuperDrive"...
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
106 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
