Question about Lands Phones
Lost manual for KX-T2370 How do I program answering machine for number of rings before taking message
rizla
  • 1463 Answers
SOURCE: how to set message for answering machine lost directions
hi is this your phone here http://evaluezone.com/dxi986-2.html
also you can get the manual from here as well .
or a search on there web site Uniden | A World Without Wires
may find the right manual .
riz.
Posted on Nov 19, 2007
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
SOURCE: IIncreasing the number of times the phone rings before message system answers
I have a Panasonic KX-TG5632 and I need to set the ring time, how do I set the ring time?
Posted on Jun 10, 2008
marked
  • 6487 Answers
SOURCE: NTL VS205 lost manual
There are two types of messages you can record onto your answer phone.
Type 1 plays your message and allows the caller to record their message for you to hear.
Type 2 plays your message but does not allow the caller to record a message.
To add your own type 1 outgoing message (OGM1) on the answer phone use the following proceedure as outlined in the manual.
From the VS205 handset
1) Press the clear/mute button - display = "TAD ON"
2) Press the 9 button then the 1 button - display = "91"
3) When you hear a beep speak your message into handset.
display = "REC OGM1". Note:- 30 seconds maximum.
4) Press 5 to stop the recording.
Your message will then play back to you.
display = "PLAY OGM1"
5) At the end of playback there will be a double beep.
The display will return to "TAD ON"
To Play/Check OGM1
1) Press Clear/Mute. Display = "TAD ON"
2) Press 6 then 1. Display = "PLAYOGM1"
Your OGM plays back inviting the caller to leave a message.
Note - To restore the pre-recorded OGM1 press "0" (Zero) at any time during playback. The display reverts to "TAD ON"
To add your own type 2 outgoing message (OGM2) on the answer phone use the following proceedure as outlined in the manual.
2) Press the 9 button then the 2 button - display = "92"
display = "REC OGM2". Note:- 30 seconds maximum.
display = "PLAY OGM2"
To Play/Check OGM1
2) Press 6 then 1. Display = "PLAYOGM2"
Your OGM plays back but should not invite the caller to leave a message.
Note - To restore the pre-recorded OGM2 press "0" (Zero) at any time during playback. The display reverts to "TAD ON"
Hope that helps.......
Posted on Jun 27, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
I cannot find how to set the number of Ring Count on my phone AND How do I set my personal Greeting for the answering machine? I've tried for 3 weeks using my 'operating instructions manual'
The manuals can be overwhelming. The KX-TGC210
manual obtained from www.manualslib.com has the
Answering System details beginning on page 29.
==============pg 29================
To summarize, "Recording your greeting message:"
press [menu] # 3 0 2
scroll to "Yes" press [select]
phone will (beep) [[ speak your message ]]
press [ stop ]
press [ off ]
==============pg 32================
To summarize, "Number of rings ..." (Ring count):
press [menu] # 2 1 1
scroll to ((your desired number of rings)) press [select]
press [ save ]
press [ off ]
May 21, 2016 | Panasonic Lands Phones
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
How do I change the number of rings before the answering machine picks up the call on my panasonic KX-T7633 phone
If this is forwarding to the answering machine on YOUR phone, from the intercom dial *713xx where xx is a number of seconds. I think by default it's using the system number of 40 or 45 seconds. Try 24 for 4 rings (or multiply the number of rings by 6 and you get seconds).
If you're talking about SYSTEM rings before the VM, it's a different story and it requires system programming.
Carl
Aug 24, 2011 | Panasonic KX-T7633 Corded Phone
How do we change the number of rings before the answering machine picks up?
It depends on how it's forwarded. If you're talking intercept ringing IRNA, then it's system program 203. If you are looking at CF-No Answer, it's programmed in system programming 619 for each extension, or by default in program 202.
These features require a Programming Manual and Installer access to the SYSTEM programming.
Carl
Nov 19, 2009 | Panasonic KX-T7453 Corded Phone
Lost manual, need to change # of rings before machine answers pho
hey u can chk in our Fixya site
http://www.fixya.com/support/p475286-panasonic_kx_tg5632_phone/manual-19838
there are pages u can go thru this Showing Page 1 out of 64
hope this help u
Aug 06, 2009 | Panasonic KX-TG5632 Phone
Set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
Feb 02, 2009 | Lands Phones
Number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
Oct 28, 2008 | Panasonic KX-TG5632 Phone
Tg5632
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Jan 29, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
103 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
