Question about Nikon D80 Digital Camera with 18-135mm Lens
Power switch The powers switch on my nikon d80 does not seem to be working. Battery is charged, making contact. Switch seems to be rotating smoothly. Internal circutry problem?
  • Anonymous May 19, 2009
    is this the known issue where a freshly charged battery reports dead battery? Mine has worked perfecty since coming back from Nikon's warranty department.
    Novelist:
  • 181 Answers
Make sure you are using a fully charged Nikon battery. Problems may sometimes happen with generic batteries. If you are using a Nikon batt, then seems you may need to bring this in for servicing
NOTE: Please rate our help to keep this free service online
Posted on Jan 08, 2010
My nikon coolpix P510 will not turn on even though the battery tests as fully charged. What can I do to fix it?
You should provide more detail, but if that is all you know about the problem, it sounds as though the power switch is defective or the battery is not making full contact. First look into the battery compartment and see if all the contacts are visible. Check the battery contacts too. If both of those are okay, and the battery is seating properly, suspect the power switch.
Sep 28, 2014 | Nikon COOLPIX P5100 Digital Camera
Nikon d3100 collapsed during firmware update
Alexandru,
I think your camera is bricked. If you did remove the battery, and after charging it again, replaced it, and it still does nothing, you only have one option. Contact a certified Nikon service centre. Tell them you tried to update the firmware of your camera, and it then it stopped working. Tell them you did everything as described. First charged the battery and only then you started the procedure.
I think they can revive your camera, but perhaps you have to bring it in, or send it to them. Don't forget to ask in advance, what it will cost if they have to put in the firmware.
Success
May 14, 2014 | Nikon Cameras
Nikon S6500 will not turn on
Could be the camera, but always first check the contacts from the battery and in the camera. Just to be sure nothing can block a free current. The contacts should be clean and shiny. Not a spec of dust is allowed in the battery holder. If you should need to clean the contacts, only use a dry cloth. Never use a sharp tool in or close to a camera. Then make sure you put in the battery the correct way. I don't know how strong you are, but sometimes people manage to put the battery in the wrong way around. Make sure the battery-camber / Memory card slot cover is closed correct. There is a little switch that indicates if the door is open or closed.
Almost impossible two batteries are dead at the same time. Unless you left them lying for a long time.
When you think everything must be right, just press the power switch several times in a row.
If nothing helps, I guess contact to a Nikon service station, or a new camera?
Jan 30, 2014 | Nikon CoolPix S6500 Red Digital Camera 16...
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
There is no electrical noise and the d80 won't take pictures. the battery is charged, the display works and the card was formatted, but i can't figure out what's wrong with it. we also checked to make...
Hi msumonica, Try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then call Nikon digital 1-800-645-6689.
Jun 19, 2010 | Nikon D80 Digital Camera with 18-135mm...
My Nikon D80 will not autofocus
Fix your issue with these steps:
1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
5. Set the camera selection wheel to manual (M), see picture
6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
7. Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
8. Turn the camera off
9. Reattach the lens. Push the lens, white point to white point and turn the lens in place.
10. This worked for me, hope it also helped you ;)
For more solutions check Nikon D80 Manual
Apr 03, 2017 | Nikon Cameras
My D80 won't power back on. while taking pictures it shut down, no LCD, no display, no response.
This may be due to a faulty battery. Make sure you change to a fully charged Nikon battery and retry.
Jul 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Kodak p850-turns off and on
Try using a liquid contact cleaner. I read about this fix on another site, worked great for me.
A product called DeoxIT in the U.S. is what was suggested, I am in Canada and can't get that here so I picked up a product from a company called NexxTech. Just a liquid contact cleaner.
Take out the battery of the camera. Put a few small drops of the contact cleaner on the power button and let it drip down into the switch. Rotate the on/off switch back and forth 5-10 times, put the battery back in and Voila! Fixed!
No more random on/off irritations, camera works just like it did before the problem arose a few weeks ago.
It worked great for me.
Good Luck!
Dec 19, 2007 | Kodak EasyShare P850 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
119 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
