Need diagram to replace belt on frigadaire front load washer
  • 365 Answers
Should be a cover at the rear of the machine that covers the belt, remove the cover to expose the belt
Posted on May 10, 2009
How to remove front of drier on frigadaire stackable
You have to remove the screws from underneath then you must remove the filter then using a lift up and slide down motion it should come away there may be just a few guide screws as well..ok.
Feb 22, 2013 | Frigidaire FEX831CS Top Load Stacked...
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
I am trying to replace a vibration shock absorber on our frigadaire front loading washer. the nylon bolt just keeps spinning and spinning. Any ideas?
yep,,, its striped its thread, get some moll grips on it and butcher it out? you will then need a new bolt,,,
darn silly idear them nylon bolts best thing for this bolt if melt it down and make stocking out of it?
Oct 23, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigadaire front load rubber smell and won't spin
just by what you are telling me it sounds like it either locked up a transmission or the belt needs to be changed
Apr 13, 2009 | Washing Machines
Frigadaire front load washer, drum is very low in
Is the drum bouncing around?
Remove the front lower panel and the top from the cabinet. Replace the shocks and/or tub support springs if they are broken.
If the spin is noisy, there might be a problem with the inner basket or the tub bearing.
Mar 05, 2009 | Frigidaire Washing Machines
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigadaire front loader washer
Water not reaching the dispenser is one of the codes.
does it fill with water.
is it on a pedestal is the drain hose below the washer?
is it getting hot and cold water.
if water is not entering ,open the top and check the wiring to the water valves (where the hoses screw on)
Feb 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
