Question about AMD (90613) PC Desktop
My PC will not boot but only displays "press F2 to enter bios setup"
I upgraded my pc to windows xp-sp2 and restarted then i uninstalled the antivirus program on my pc it prompted for a restatrt and then it displays "Press F2 to enter setup" and even when i press F2 it still will not boot.
  • Abdulhakim Haliru Oct 15, 2007
    not helpful  but thanks. it turned out that i fix it by replacing the RAM.
  • 1,006 Answers
Go to BIOS and go to LOAD SETUP DEFAULT OR LOAD OPTIMIZED DEFAULT -YESS- AND RESTART
Posted on Oct 12, 2007
Slow boot up
Diagnosis your hard drive from bios or press F2 while restarting to diagnosis hard drive.
Scan with updated antivirus tools.
Press and hold window key and press "R" key
Type rstrui and Enter
Click next
Select any previous restore point and restore
If still nothing change restart your pc
Now press F11 and re set to factory setup.
May 12, 2013 | Toshiba Computers & Internet
Proper booting up, what needed to type f4 or f2
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
Dec 01, 2012 | Microsoft Windows XP Professional With...
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
My pc is pen iii is using window 98, i remove the disc and upgrade it in another pc with xp.i put it (disc) back in my system, but is not booting
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 11, 2010 | Computers & Internet
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
System not booting harddisk connected in master &cd drive conected in slave os win xp sp2 wts the main problem
plz set ur hardisk as the 1st boot device in the bios setup. u can enter the bios setup by pressing the del or f2 key when u power on the mission
Feb 21, 2009 | Microsoft Windows XP Professional for PC
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
How to install Windows XP Professional SP2
Check this Sol'n..
1. Boot(start) ur computer.
2. Press F2 to open up your BIOS Setup
3. Go to boot menu and set the 1st boot order to CD drive using function key. ex. F5
4. Change the SATA settings to IDE. Not
5. Save the new settings using function key before exiting. Ex. F10
It will restart and surely boot on your XP cd (if inserted)..
The rest are typical OS procedure.
From
#14DeeP
CCC-OTC Computer Operator
Mar 09, 2008 | Computers & Internet
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
AMD (90613) PC Desktop Logo
101 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
