Question about Bosch 24 in. SHU43 Built-in Dishwasher
No water pressure
I have a Bosch SHU4306UC dishwasher. When I run it, water fills the tub at the bottom but no matter how long it runs, no water shoots out of the arms, so the dishes don't get washed. It is like there is no water pressure. What can I do?
  • Anonymous May 12, 2009
    Bosch shu9915 suddenly started making loud noise emanating from right side as you look at machine. No water pressure and soap flap did not open.
jgwhomeequip
  • 1902 Answers
SOURCE: Bosch Dishwasher SHU43C Not Washing Dishes
Check for plugged nozzles
Posted on Feb 08, 2009
SOURCE: Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Posted on Sep 20, 2007
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bosch SHU53A dischwasher runs continuously without water
check and see if there is water in the base by removing the toe kick. if so then it activated your float micro switch. clear the water from the base. i use a wet vac, but if you don't have one just soak it up with towels. once that styrofoam piece on the left side of the base isnt submerged in water anymore then it should start. it could be a broken hose or bad part. check hoses if you have a rat or mouse lingering. otherwise i have also seen flexable cutting boards blocking the condensation hole on the inside of the tank on the right wall. if you think it was that then just keep those flexy cutting boards on the left side or top rack.
if no water is down there.. then where that styrofoam piece sets on the left side. find that red plastic rod and flip it upward a few times to un-stick the float switch with the dishwasher unplugged first of course.
Posted on Mar 19, 2009
My Bosch dishwasher SHU43C won't fill. husband used plunger in kitchen sink many times throughout the day. we didnt realize the water was being forced back down the dishwasher drain valve and filling the...
You need to clean that contaminated out of the dishwasher and clean the water level float and the screen at the bottom of the washer tub.
Jul 13, 2017 | Dishwashers
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have an integra shx46a that keeps on running and running for several hours and when it completes the dishes are still dirty. I cannot find the directions for the self diagnosis that In know some Bosch...
most bosch dishwashers have a filter that can be removed and cleaned at the bottom of the tub check filter to see if it is dirty. if the filter is clean make sure your water is hot enough min 120 degrees at faucet may want to run hot water at sink before starting dishwasher
May 12, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
177 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
