Question about Kenwood KAC-848 Car Audio Amplifier
Kenwood KAC-848 amp not working
My old trusty Kenwood just went mute as I was driving. The power light comes on, but there's a *pop* coming from the speakers in a steady half-a second interval without any other signal. Also at the exact time I hear the *pop* the power light flickers once. I have no idea what this problem can be, since my grounding is fine (it worked before) and AFAIK I haven't overheated it.
  • Bug This Oct 11, 2007
    The power light of the amp flickers, that is
  • Anonymous Apr 29, 2008
    As i drove for a few seconds my Kenwood amp emitted a popping noise that persisted for a while, as I checked my amp I noticed that the power lights was blinking on and off, I bought a new wiring kit but that didn't help,
Resolder all connections on the mainboard to the transformer and to the speaker jacks. Also check the emitter resitors.
Posted on Jun 05, 2008
  • 631 Answers
It sounds like the amplifier is going into protection mode. This is generally due to shorted output transistors but can also be caused by shorted wiring. Disconnect all of the speaker wires and signal cables from the amp. If it still does the same thing, confirm that you have adequate voltage across the B+ and ground terminals (at least 11 volts DC). If the votlage acrosss the terminals is OK and the light still flashes with no speakers connected to it, the amplifier is in need of repair.
Posted on Oct 11, 2007
SOURCE:
What is the rms outpur of my kenwood KAC 848 amp
rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Jul 28, 2010 | Kenwood KAC-848 Car Audio Amplifier
Sudenly quit working
Contact Eric @ Capital Audio & Electronics Repair in Tallahassee,FL 850-339-1130 we repair all name brands & all Models
Mar 09, 2010 | Kenwood KAC-848 Car Audio Amplifier
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
My sons kac 848 amp just stopped working
There is an Internal Fuse on Most of these Models that will blow from time to time. You might also check the Ground Connection. A loose Ground can cause the Same Problem. Please Rate My Response! Thanks!
Feb 02, 2009 | Kenwood KAC-848 Car Audio Amplifier
Kendwood kac-848 audio problem
Are you sure you have the speakers wired to present a safe load to the amp?
Aug 11, 2008 | Kenwood KAC-848 Car Audio Amplifier
Kenwood kac-848
You have blown outputs , faulty channels. What kind of amp do u have and what were u running to it? Most likely a bad amp, u might need a new one.
Jan 24, 2008 | Kenwood KAC-848 Car Audio Amplifier
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Car Audio & Video Logo
205 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
