system file you cannot delete if personal file.....delete directly if attacked by virus some file couldnt be if it it so backup yor data make hard reset of your device to factory setting
Select system settings, then select data management, Select the "System Memory" tab to delete files from the Nintendo DS system memory. Select the "SD Card" tab to delete files from an SD card. A list of saved files on the system memory or SD card will appear. Select the saved file you want to erase from the list. A prompt will appear. Choose "Delete" from the prompt and confirm you want to delete the file. The saved file will be immediately erased from the system memory or SD card of the Nintendo DS.
Click on "Menu," and then "Tools," and then "File Manager."
Select "Browse."
Navigate to the directory "c:system\apps\commwarrior," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
Navigate to the directory "c:\system\updates," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
Navigate to the directory "c:\system\recogs," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop. Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was. 2. It runs from the driver folder in system 32 folder 3. it auto runs at system startup 4. It makes the computer boot slowly 5. It makes your computer to hang. 6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
So why you didn't format your system?!!
Make a backup from your files and then format your system and make a new partion for it and then install your OS.
It could save you!
Audio files are songs. I hope you don't mean system files. If you deleted system files or folders, go to RCA's website and get the firmware upgrade - hopefully it will add those files back.
