Question about Behringer ULTRALINK UL2000M Microphone
ULTRALINK UL2000M when I turn on the base o my Ultralink ULM2000M the display say error 05 What Can I do please
Stuck key on machine wont start
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 35 9 35i Treadmills Consumer SPORTSMITH net
Jul 22, 2014 | Precor 9.35 Premium Series Treadmill
Stuck key
Corrective Action
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Jul 15, 2014 | Precor 9.33 Treadmill
Precor gfx 9.33i displays "stuck key"
Corrective Action
Apr 20, 2014 | Precor Deck, Treadmill, OEM
I have a PrecorC956 that displays a stuck key & won't start.
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
Corrective Action
Repair Parts for Precor C956 Treadmills 120VAC 240VAC SPORTSMITH net
Mar 02, 2014 | Precor C956i Treadmills with HR /...
I have a ps3 and a 40" tv connecting the two are a hdmi cable and a ultralink cable sadly i dont understand what the ultra link is for any help?
If you have HDMI cabe you dont need a ultralink cable because the HDMI does what the ultralink do but better.
Mar 06, 2011 | Video Game Consoles & Games
What HDMI to DVI-D cable will work with Philips 60PP9352 60 in. Rear Projection Television? Please help. I've looked everywhere and can't seem to find one.
Get an HDMI to DVI adaptor and use a generic HDMI cable.
Lots of DVI MALE to HDMI FEMALE adaptors out there:
Ultralink, Monoprice, Monster etc.
Jan 01, 2010 | Philips 60PP9352 60" Rear Projection...
When I turn on my mic the display says err 05.. any fixes
Here's the link to the manual:http://www.behringer.com/EN/downloads/pdf/UL2000M_P0134_M_EN.pdf Here's where you can ask them:http://www.behringer.com/EN/Support/Online-Support.aspx
Oct 17, 2009 | Behringer ULTRALINK UL2000M Microphone
Problem with Marantz DV 7001 DVD player
i am not an expert, but I have read that it is important to make sure the Marantz is set to the same resolution to your tv. If not you will have blanks screens.
Let me know if it works. I just got one for my mom.
Mar 04, 2008 | Televison & Video
Switcing on
Here is the link to the product page on the website - there you can find the user manual and much more; http://www.behringer.com/UL2000M/index.cfm?lang=ENG check page 12 and 13 about channel selection, and page 24 has a good summary of the procedure. If you still have a problem after doing this then there is almost certainly a fault - the fact that you got it working once would indicate that the switch itself, or a connection inside the mic near the switch may be the problem. If you fancy trying to hunt this fault down yourself and want some pointers, please post again, if not it may be cheaper to get a new mic than to get it repaired professionally, but ask for a quote just to check this. Hope this helps :)
Apr 03, 2007 | Behringer Ultralink WMI2000 Professional...
Behringer ULTRALINK UL2000M Microphone Logo
105 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
