Question about Toro Lawn Mower With Toro Power Tools
John deere js60 lawnmower
Havnt used in 3 yrs, changed sparkplug and wont turn over... spryed quickstart in spark plug socket and will turn over for 4 seconds then turn off again. put new gas in as well, is there a choke or speed control on the mower
  • 246 Answers
Hello:
It Sounds like the Carburetor Requires Soaking and Cleaning.
You can View a Breakdown of this Unit at the Following Site Addy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Enter the Model Numbers JS60 and then Select the Sectional Index. Now Select the Section of the Mower or Engine you Wish to View.
Hope this Helps.
Good Luck
Respectfully
John
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
John deere riding mower wont turn over unless plug is out
IF you have to remove the spark plug to get the engine to crank, check to see when the motor is in the compression stroke and go just past that point and try again to see if the motor cranks with the spark plug back in. 3 of 4 piston motions are not related to compression. If it does not move then the starter does not have enough torque.
May 13, 2015 | John Deere Garden
Where is the spark plug?
The spark plug will be located on the engine under a rubber "boot". Remove this boot and you will see the spark plug. The boot is attached to the spark plug wire, you should be able to spot it pretty easily.
Grip the boot and pull it off, it will have a little resistance, but it should come off with no problem.
You will need either a spark plug wrench or a deep socket wrench to remove the spark plug itself.
Only use the tool the loosen it, then use your fingers when you can.
Good Luck!
I've added a link to a post about how to change the spark plug on a lawn tractor, unfortunately, it is not John Deere, but it should be very similar!
How to Change the Spark Plugs on Simplicity Broadmoor Lawn Tractor
Mar 24, 2015 | John Deere Garden
My JD lawnmower won't start. Starter is good. Replaced Cylinoid. Removed spark plug...too much gas there.
clean out the carbi needle valve,wind engine over without sparkplug for a while,say 15 seconds.leave for an hour before putting plug back in.
Jul 26, 2014 | Rc2 116 John Deere 125 Lawn Tractor
I cant find spark plugs
I am writing you the method on how to change sparkplugs, you may now have an idea where spark plug is loacted.
The Ford Expedition uses eight spark plugs to accommodateits eight-cylinder engine. Replacing the spark plugs every 75,000 miles is animportant part of overall vehicle maintenance. 1. Disconnectthe negative (black) battery cable from the battery terminal. Remove thewiring harnesses from the spark plug coils. There will be four on each side ofthe engine block, which you can remove by simply pulling them out of the sparkplug coils. 2. Unscrew the 7mm bolt from each of the spark plug coils usinga socket wrench and 7mm socket. 3. Pull each spark plug coil out of the engine block. Pull themout slowly, being careful not to damage or tear the coils. 4. Use a socket wrench and spark plug socket to unscrew eachspark plug from the engine block. Once you remove these, discard them. 5. Place the new spark plugs into the engine block and tightenthem using the socket wrench and spark plug socket. 6. Slide the spark plug coils back into the engine block. 7. Bolt the spark plug coils back into place using a socketwrench and 7mm socket. 8. Reattachthe wiring harnesses to the spark plug coils. 9 . Connect the negative battery cable to the negative batteryterminal.
Nov 25, 2010 | 2003 Ford Expedition
The lawnmower wont start it made a loud poping noise and now it wont start it turns so its not locked up i tried checking the fuel system that is working fine i also changed the spark plug
I suggest taking off the little valve covers next to the spark plugs and see if you have bent valve push rods, not uncommon with today's gas. This means that though your crank turns and your pistons move up and down, there is no opening/closing going on to let mixture in or exhaust out. If that is your problem they are easy to replace, but I would get an expert to adjust the new ones once they are in.
Oct 12, 2010 | John Deere Garden
I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Jul 10, 2009 | Garden
John deere js60 lawnmower is fouling the spark plug in 20 minutes. gas is good other mower works fine with same gas. can not locate fuel filter if it has one. large deposit of smut on plug.
sounds like your carb. is running rich for some reason
be sure to check to be sure your choke is fully off when running
follow your fuel lines they may have stuck the filter somewhere or they may be only using a tank screen filter.
Be sure you have the proper plug installed and gapped .030
most common plugs that are used the most is J19LM or RC12 YC
couple things to check for you mowers issue
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
732 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
