Question about Toshiba e-STUDIO 16 Printer
E studio 16
Show paper jam, but i cannot find jam anywhere, i have taken fuser out, no jam i can see in fuser, the drum unit is also stuck, I cannot get it out, could this be the problem with paper jam? Also error code E03. whn holding stop and 8 keys together.
Any help will be greatley appreciated.
Billy Barbour
E-tech Service center
Danville, Ky
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Posted on Oct 20, 2007
Brother 2270 laser printer started jamming every time, after I installed a new toner. It was a Brother toner, at that. Anyone experience this?
Silly question first - is the drum unit DR2225 installed?
Check the toner cartridge sits firmly in the drum and that the drum is pushed all the way forward in the internal cavity. If the paper is jamming at the paper pick up roller ie in the paper tray, clean the paper pick up roller with a drop of meths and a drop of detergent on a damp cloth. If the paper jams in the drum unit, check the clear plastic guide flaps are straight and do not catch the paper. Also check that there is not a piece of paper caught in the drum unit. If the paper gets part way through the drum and then jams, check the fuser at the back for a piece of paper crumpled up inside the fuser. If the printer is trying to take ALL the paper at once, check and clean the paper separation shoe in the paper tray.
Jan 03, 2018 | Brother MFC-7820N Laser Printer
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Jan 11, 2009 | Toshiba 2060 Copier
Toshiba fax #DP 125F
Open the top cover.
Remove the toner and drum cartridge. Where the paper comes out you'll see a cover for the fuser held by two screws. Remove the screws, pull straight up to remove that cover. The fuser is there.
Check the eject switch actuator. mounted on top of the fuser, it might be broken.
Sep 26, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Oct 12, 2007 | Toshiba E-STUDIO 650 Copier
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
Toshiba e-STUDIO 16 Printer Logo
516 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
