Msi "m-7185" PSU shuts down after startup
My hiper Type-r 580w PSU shuts down between 3 and 15 seconds after startup. The minifan and LED remain powered.
I am presuming this is an overload trip.
If I disconnect the 2 pin cable from the PSU to the MSI motherboard the PSU does not shut down. (The 2 pin cable connects to the PSU end of the motherboard - away from the video card).
With this cable disconnected the PSU runs OK, with no shutdown. I have no video but I can hear the HD doing it's normal 'hard work' for 30 seconds at start up.
It would appear that it is not connecting to the router, as it is not visioble from another computer.
Any suggestions welcome.
ColinK
I have a Toshiba TV/Combo The set will turn on then it turns of in a second. It will not stay on.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jul 14, 2010 | Toshiba Televison & Video
Television will not fully power up to standby mode. Standby power indicator light repeatedly blinks in a weakish manner as if trying to fully turn on, along with simultaneously sync-ed popping noise, when...
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. It is the sound that gives it away. This happens so that no further damage, and possible fire will occur. It is probably the PSU.
Feb 02, 2010 | Akai LCT2715 27 in. LCD Television
No picture or sound, standby led flashes 11 times when first turned on after AC plug has been removed and reinserted into the AC outlet. Every attempt to turn on after the initial attempt yields 6 flashes...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The flashing LED is justa coincidence I would think.
Jan 22, 2010 | Sony KP-53HS10 TV
72" sony wega HDTV turns on and stays on for about 20 seconds then turns off for about 30 seconds then comes back on but without sound for about 5 seconds
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. Then after it has reset, it tries to startup again, over and over, it would do this until if fails completely. This happens so that no further damage, and possible fire will occur.
Jan 22, 2010 | Televison & Video
4 second shutoff
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem. Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
Jan 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have replaced my MSI MS-6741 motherboard with a MS-7142 v1 type. Everything is connected up ok but when I press the on button the LEDs come on and the fans start up for about 1 second, then the whole lot...
Pull the battery, short the BIOS shorting pins (depends on your model where that is) for a minute or so. Make sure you have the correct memory (usually the problem) and reinsert battery and restart.
Apr 29, 2009 | MSI K8MM-V Motherboard
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Hi, I don't seem to be getting an output from my Hiper Type R 580W power supply.Do you know if it operates as sense and return as the supply is not connected to the load at present. ...
The power supply has to have a load. There is a sense line on the ps/mb. You can purchase a ps tester from Internet vendors that will plug onto the ps connector and show if it is working on not.
Aug 18, 2008 | Computers & Internet
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
