Question about JVC AV-27D302 27" TV
No display in the top 4" area and a slight reflection of the top 4" or etc appears in the next 4" area below. 1. If this is a major board problem, is purchasing a board or another TV my best option? What is the cost of a board if this is the problem? 2. Is there a charge for your verbal consultation? Thanks Joe
    An expert who has answered 500 questions.
  • 556 Answers
Re: No display in the top 4" area and a slight reflection...
Your problem is called fold over.
this is due to vertical section
you can check the following
loose contact in vertical output feed back circuit.
electrolytic capacitor failure in vertical output ckt.(THIS IS VERY VERY COMMON PROBLEM  as after few years capacitor gets dry)
 If this is a major board problem,?
no, not major problem
no need to go for new tv
as per charge is concern it should be nominal.
hope this will help.
Posted on Oct 12, 2007
0 characters
3 Points
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
Top ~1¼" of the picture being overscanned into top ~½"
a missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage
Thanks for using Fixya!
Sep 19, 2008 | Philips Magnavox 20MT133S 20" TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
The problem I am having is that my 32' Sony Wega kv32fs12 Trinitron television will work almost perfectly. Image color is beautiful. tuners seem to be working like a charm, but the screen has a slight...
Picture alignments made in servive menu.
pwr off + display + 5 + (+vol) + pwr on
You must do all within 1 second.
1&4 move thru settings, 6&3 chg value,
muting & enter saves chgs.
Your code access could differ.
In the menu note down all existing settings.
Make small adjustments and watch what happens if not in right direction reset that particular option to original value before you changed. In those menus you can bend, shift hor. and vert., etc.
But be warned only slight adjustments and write down start values before experimenting. Or you can get in to serious trouble.
Good secret service menues keep an access counter for manufacturer/dealer to see how many times it was used.
May 04, 2009 | Sony KV-32FS12 32" TV
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
TV powers off after an hour or so
Hi Chuck, intermittents will definitely try your patience, It`s obvious the problem is with a poor solder connection or loose plug/connection. It would help immensely if you would tell us make and model number of the set. From your description I would unplu AC cord flip the main board over, get a bright light and a magnifying glass and start checking your solder connections, I`ll bet you have several, check closely low voltage power supply area (where your AC cord attatches to the set) and the high voltage area where the flyback is (large plastic part with large red or black wire coming out of the top), your looking for connections that are cracked or dull grey (overheated) solder, if you need more help keep asking thats what were here for, good luck, BMW Rider
Dec 05, 2007 | Standard (CRT) Televisions
RGB colours all over
it is due to magnetic effect in television due to problem in degaussing circuit. solution 1 remove the things which have got magnetic effect like speaker, phone etc. 2 change the direction of tv. 3 do not change the direction when tv is on. 4 call tech. to degauss it by using degaussing coil at your place. 5 it is not a major problem.
Sep 30, 2007 | Standard (CRT) Televisions
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
JVC AV-27D302 27" TV Logo
32 people viewed this question
Top JVC Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a JVC Standard (CRT) Television Expert? Answer questions, earn points and help others
