Question about Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
  • heatguy May 11, 2010
    if you have model # you can call moen describe whats goin on and they will send you parts for free as long as you are homeowner not pro
  • Samuel Charles Spriggs May 11, 2010
    Sounds like two problems. Yes, it can be fixed. Are you up to giving it a shot? Let me know,
Check underneath spout ... if is plastic then is a "less expensive" model and the base and some internal parts may be also made of plastic. Is it a model 7100,7400 or 7600? this appears on stem on opposite side of spout... The base may be "out of round" (or "eccentric") from many yearsand may continue to leak even after replacing bottom o-ring. I have learned that if the faucet is older and plastic, advise the person to invest the money in a new Moen faucet: if you are paying someone to do the work, save time & money by having them make the switch instead of tryting to fix w/ a new o-ring, if you want to try to dis-assemble faucet and replace o-ring:
While you are changing o-ring might as well replace cartridge, get cartridge form same place you get o-ring, cartridges are supposed to be free (depending on hardware store) ...someone there should be able to help w/ dissasembly .. i hope ..
Plug drain(s) add some warm water to sink to be able to wash and rinse parts if needed, shut water off, relieve pressure by turning tap on ... plug drains!!! (tiny screws love drains...)
Most MOEN single handles: just pull top off straight up, most are just press fit on. This exposes screw. Before taking screw out make sure you have a clear area to set parts in order of removal taking care to remember alignment and order. Remove screw ...
Internal parts are usually threaded plastic so go easy on things ... unscrew retainers, remove lever control making note on how it engages the cartridge etc... this helps you figure out re-assembly
pull entire spout housing straight up (might resist a bit if crudded up) hold up to light and see if out of round.. you'll now see the brass interior...pinch out o-ring and replace. Silicone lubricant may help (get from same place as o-ring, cart. they should have little free packs..) slide spout housing back over ... re-assemble all in reverse, do not over-tighten plastic retainers, hand-tight ok .. if still leaks
might want a new one ... hope this helps
Posted on May 17, 2009
  • 23 Answers
Base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
Posted on May 12, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I have a single lever Moen Kitchen faucet that is leaking around the base on top what might be wrong with it
    You need to replace the spout o-ring seals. A Moen #117 spout oring kit. If you have a faucet with a sprayer, you will use all three rings. If uit has no spray, you will use only two.
    Apr 19, 2016 | Moen Plumbing
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
    If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
    Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
    Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
    Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    Moen kitchen faucet leak from spray
    This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
    Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    My moen single lever faucet is loose, how do I tighten it?
    On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
    Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    6,528 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
