Question about Saniflo & Saniplus& Macerator Pump
Brand new saniflow wont run, all electrics fine, any help??
  • nivek1 May 11, 2010
    Any sound at all from it? Humming or buzzing?
    Scholar:
  • Saniflo Expert
  • 115 Answers
The Saniplus takes about 1.6 gallons of water to turn on and off. Is it tripping the GFI? If it trips the GFI then the pressure chamber might be broken and is where the electrical components are. The pressure chamber will need to be replaced if cracked or broken. I'm a handy man and one of my customer had the same issue. We replaced the pressure chamber complete and it fixed the problem. Also make sure you are using a 15amp ground fault interruptor.
Posted on Jul 23, 2010
Local authority state saniflow may choke at rainwater trap and will not accept saniflow going into rainwater drain
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain.
Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out.
Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
Feb 03, 2018 | Saniflo Plumbing
Brand new dishwasher wont run
Because it doesn't have legs??? Seriously, I need a little more information. Make/model, new unit or replacement? I presume you installed it because an installer can't leave until it works. Is this dishwasher replacing an old one or a new install? Is the electrical tied in correctly? Is the water hooked up and running? Info, info, info!
Oct 19, 2013 | Whirlpool Dishwashers
Saniflow runs, but not straight after flushing
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Jan 30, 2013 | Saniflo Home
Saniflow macerater wont stop running
sounds like a stick float vave check this link on maintenance of your system.
Check the masserator is clear also check the outflow pipe , maybe a good clean see this link for more info
This will may help.
Dec 01, 2012 | Saniflo & Saniplus& Macerator Pump
Toilet wont flush
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
Can I get a replacement cap for the vent on the lid of my Saniflow system ?
I've been told that any spare part can be purchased through Saniflo at 800-571-8191. If you are buying a brand new pump then it will have to be purchased through a Saniflo distributor.
Sep 11, 2010 | Saniflo & Saniplus& Macerator Pump
Pump wont shut off
You need to check the following: Nothing connected to the saniflow is running e.g. tap dripping, ball valve in toilet cistern stuck/faulty
Any of these faults will cause the saniflo to run continuously. If none of these are visible then there is a chance that a flow switch is stuck or faulty within the unit.
I would carry out the checks first then call in an expert to service the unit.
I hope this helps.
Jul 08, 2009 | Saniflo Home
03 GMC sierra 1500 sle wont start..
if your check engine light is on,yes.it worked for me.
Mar 27, 2009 | 2003 GMC Sierra 1500
Saniflo & Saniplus& Macerator Pump  Logo
402 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
