Question about Optics
Case is "sticky" like glue
Have vivitar series one 7-16X25 Zoom (maybe ten years old). Under cover for several years, but when taken out, the case (not the rubber grip) appears to have degassed, and is extremely "sticky." What can be used to remove sticky substance, and not ruin binoculars?
The same thing happened with my old Praktica Sport Zoom binoculars, and (in my case) found that the sticky coating could be removed by repeated rubbing with paper towels moistened with methylated spirit ("meths"). SAFETY FIRST: If you decide to try this method and have not used meths before, it is a very flammable liquid, and harmful by touch and inhalation, so please wear rubber gloves and do this outdoors or in a well ventilated place and away from sources of heat or fire. That said, it is cheap and readily available from DIY stores, usually in their painting section.
Posted on May 20, 2009
Vivitar binoculars housing very sticky old but never used
I have had a similar experience with Bushnell(NOT Vivitar). I called them and they offered to replace/repair them for a shipping/handling charge. If I remember correctly it was between $15 and $20. After pricing new ones, this seemed like a good resolution. I sent them in(my cost) with a check for their S & H. A few weeks later I had new ones from the manufacturer. I think there were a few years when the industry was using a "special armor coating" which turned sticky after a number of years.
Aug 16, 2012 | Vivitar MagnaCam Binocular/ Digital Camera
Handle broke off microwave
lLAST TIME MY GE MICRO HANDLE BROKE IT WAS 179 FOR REPAIR
IT BROKE AGAIN AT THE TOP
AS ITS TEN YEARS OLD I JUST PUT CRAZY GLUE AT THE TOP AND THEN TOOK AN OLD RUBBER HANDLE FROM A CAN OPENER AND TAPED IT WITH ELECTRICAL TAPE TO THE INSIDE TOP OF THE HANDLE THIS WAY THE HANDLE CAN ONLY BE OPENED FROM THE BOTTOM NEXT I WILL TRY TO GLUE THE CAN OPENER HANDLE TO THE BACK OF THE MICRO HANDLE AND REMOVE THE TAPE
Jan 28, 2012 | GE Advantium 120 Convection/Microwave Oven
My yukon sightmark sm650 rangefinder laser is not working.The golf shop sold me a "Parview LS650" after looking around the internet, it looks exactly like the sm650. To my question....the laser...
Take it apart by peeling away rubber cover and then remove two mounting screws. Carefully split cases and see where parts are arranged just in case they shift. Laser and lens frequently get jarred loose ESP in a golf cart environment. Place laser and lens if loose back in mounts and gluon in place with superglue or equivalent. Make sure to get no glue on lenses. Reassemble and it should be good to go again. Total time. Ten minutes maybe.
Jun 09, 2011 | Yukon SightMark SM650 Rangefinder
The rubber casing has gone sticky
Many cameras and binoculars are covered with a sprayed on thin layer of rubber which breaks down after about 5 to ten years. It becomes very sticky and can be scratched off with a fingernail. This leaves a messy surface which can be cleaned off with methylated spirits. Other solvents will work like isopropyl alcahol but avoid using solvents like cellulose thinners or white spirit as this can attack the underlying plastic on some cameras.
May 21, 2011 | Praktica Optics
I have a Vivitar ViviCamx024 camera wish I received as a xmas gift from my son I can't get the battery cover to go back on the camera and top part where holder is broke and the top were the power on and...
This camera ought to be under some kind of warranty if it is less than a year old, but I have no idea what that warranty might be. In the UK, normally within the first year you can return faulty items to the place where they were purchased for some kind of remedy. Elsewhere, you may need to apply to the manufacturer. You would need proof of purchase, and maybe the warranty documents, which your son may still have.
However, from your description of the problem, the retailer or manufacturer or service center may take the position that the camera has been damaged by dropping it or similar, which would not be covered by a warranty. Perhaps it would be covered under a household insurance policy.
Fixing an item like this is not always economic, particularly if you have to pay for it yourself. Even under warranty, the manufacturer will often just replace it with a new item rather than try to fix it. Perhaps you should look for a new camera, or let your son know that you are having another birthday this year!
Nov 09, 2010 | Vivitar Cameras
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Mar 10, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Canon MVX250i Zoom
found the solution somewhere else on the net: just leave the camera lying with the batterie taken out for a while and it works again
Jan 01, 2008 | Canon MVX250I Mini DV Digital Camcorder
No startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Feb 14, 2007 | Olympus Stylus 400 Digital Camera
Optics Logo
1,786 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
