Question about Refrigerators
I have a LG LRSC 26925TT sise-by-side. A loud fan noise(clacking sound) is heard when "something" stops running. I checked the plastic fan that cools the coils an it is tight and not close to anything that it can hit. It there another fan blade area that can be checked or another item to look at? Thank you, Patrick
  • 3 more comments
  • pyoas May 09, 2009
    I had the fridge out in the open with the lower back cover off and plugged and unplugged the power to it and observed the fan. The noise did occur when I did this. Why would it only do this when I placed the cover back on, which does not touch the fan area, and not when the cover is off?
    Thanks,
    Patrick
    I meant to say that there is no noise with the back off when I unpolug and plug back in the power cord.
    Thanks,
    Patrick
  • pyoas May 10, 2009
    Is there more than one fan in my fridge? I ask this because the fan that cools the compressor coils has a significant amount of room around it and it appears that bending the plastic blades would not have much affect on it. This fan is "clean", no lint, etc.
    If there's a second fan, as referred to in an earlier post as a "FF", freezer fan, where is the access to it so I can look at it?
    Thanks,
    Patrick
  • pyoas May 12, 2009
    Thank you for the 3 tech's that posted possible solutions to my problem.
    Here's what I did today: removed the freezer inside covers to get to the freezer fan. Fan looks like the one listed on one of the posts as #1330410. Actual LG # is 4681JB1017D. It has th shape ans 3 wires. The end shaft has about 1/2" of play. Other than that it looks okay. The fan blades are plastic and can't be bent for clearance but it doesn't appear to be hitting anything.
    I reinstalled it and felt air coming from the lower vent area of the inside panel. The loud clacking sound was heard again later after I closed the fridge doors, etc. I checked the motor for operation and still felt air coming out of the vent holes. I assume this motor was still running because of felling airflow. Could it be hitting something or "?" on it's startup? Is there another fan motor besides the one for the compressor coils on the backside and the freezer motor that needs to be checked too?
    Thank you,
    Patrick
  • pyoas May 18, 2009
    I did not see this fan when I opened up the inside freezer panels but I did see fan #1330410. I replaced the 1330410 fan and it did not fix the "noise". It appears to be a fan blade hitting something when it turns off. Where is the fan located that you describe? The fan that is accessible behind the fridge located behind the back side bottom panel is not hitting anything and does not make noise when I unpluf the fridge. There is something that is running that makes the nosie described when it is shtting off.
    Thanks,
    Patrick
    Sergeant:
    Champion:
  • 219 Answers
well i think the fan blade is hitting the sorrounded shield. in my view u should get it chek by a mechanic as ur fan might need to be replaced.
Thanks!
Sandy
Posted on May 18, 2009
  • 527 Answers
Sir,
Check this link for more info.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 13, 2009
    Scholar:
  • 123 Answers
you need a new evaporator(freezer) fan motor.
This is the model
I have a LG LRSC - 00082692.jpgmotor,dc freezer
Just take off your inside back freezer panel.Then remove the fan duct, then you can get good access to the fan motor.
Posted on May 10, 2009
    Genius:
  • 1,142 Answers
the crackling noise is coming from the motor guide itself its the motor guide which has gone bad the gears inside the motor guide has gone bad so it needs a replacement, its not the fan blade or its not touching anything on the body so it the motor guide i am sending you the picture too, you can order online and get it shipped to your door step in case you are comfortable in replacing the part
Posted on May 09, 2009
  • 15,935 Answers
With the cover on all air is directed through the outlet, and as the fan winds down - there is a resistance to the flow of air....
as it slows down - the resistance causes the fins to bend slightly - and it hits on the shroud.
when the panel is off - the blades are free-wheeling with no resistance to bend the blades.
A quick fix is to slightly over-bend the fan blades so there is a greated gap between the shroud and spinning blades.
Also clean the fan blades of any lint & dirt to correct any balance problem.
Thank for using FixYa!!
My Brother PE-770 presser foot Q has started making a clacking noise. If I press in on the lever on the back of the foot, the clacking stops. What is causing this loud noise and how do it fix it?
Sounds like something in the machine in the head that makes it go up and down. either wear or something loose. I would have it checked by a Brothers repair shop
Jan 10, 2015 | Brother PE-770 Embroidery Machine
I have a LG refrigerator LRSC 26925TT and I need to replace the Ice Tray - How do I do this?
most ref have ice makers. but if yours does not the the ice tray can be pruchased from l g / they are there own dist and most part supply houses do not have there parts . however sear's is a good source / try there web sight and i think you can order it there . i works for me ... mm
Oct 10, 2010 | LG LSC26905TT Side by Side Refrigerator
I woke up to a loud buzzing sound from the freezer side, behind the automatic ice maker. Sounds like a fan? Model LRSC 26941SW.
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Good luck!!!!!!!!!!!!!!
Aug 04, 2010 | LG LSC26905TT Side by Side Refrigerator
Special sound comes from back side. after that no cool now.
pull unit away from wall look for fan that cools evaporator coils see if its running check to make sure nothing is obstructing movement
Apr 15, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG LSC26905tt inside freezer fan is very loud and it has never done this before, what can be the solution for this?
there could be ice buildup around the fan housing, unplug unit and use a hairdryer to deice around the fan housing
Oct 30, 2009 | LG LRSC-26922 Side by Side Refrigerator
Fan is making a loud noise by the ice maker. Sounds like it is rubing against something. It turns off when you open either door.
the fans normally stop when you open door fan probably has ice or frost in cover area remove food from area and check cover make sure not cracked and pushing in on fan also check and see that fan doesnt have plastic or foil stuck in it if ice dont have to defrost whole system clear food away and use a hair dryer on high directed on fan housing after a few min 8-10 check fan to see if ice or frost is gone
Sep 28, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
