Question about Roper REX4634KQ Electric Dryer
Dryer fuses are always dying and I have no heat
I have a brand new roper dryer that the fuses are always dying on me at least once a month i have to change. I have 220 going into the dryer what do I look for to solve this issue.
  • 460 Answers
The fuses are doing a  great job 4U, they burn up instead  of U or your dryer.
If you having this problem is because these a bad circuit, please be sure to talk to a relative or a friend about this electric issue.
I also found this
 (check that the fuses are firmly seated, clean the contacts if they look dirty).  Fuse contacts are not designed to heat up and will eventually "burn-in" when they become resistive.
Fuses will protecting you n your love once against fire because eventually wit out it will cause fire.
"Was this helpful?"
Posted on May 09, 2009
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Where is roper thermal fuse, its an older dryer
On older Whirlpool brand dryers(roper is made by Whirlpool) the thermal fuse is usually always in the blower housing..to get to it ya would need to remove the back panel.
This video shows who to replace the thermal fuse http://www.youtube.com/watch?v=aUQQJAxkZ0g
GENE
Sep 16, 2011 | Roper RES7646KQ Electric Dryer
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
It just stopped working no funny smell nothing itr is a roper mod red 44405Q0
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Roper Dryers
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper Dryer won't heat
check the upper and lower limit switches on the heating duct. they act like fuses and and pop if the go bad. to check. first unplug dryer then remove back panel. the heat tube should be on the right and have two disc looking things with two wires going to them. check top one first. pull wires off and with jumper wire connect the two wires together. now plug dryer in and check to see if it heats. if not check the lower one. do not run dryer for longer then i takes to see if coils heat up. if still no heat then u need to pull heating element off and check for an open in the coil.
Jan 30, 2009 | Roper REX4634KQ Electric Dryer
Gas dryer not heating
REPLACE THERMAL FUSE #3392519 AND CLEAN YOUR VENTING GOING TO WHERE
IT EXITS THE HOUSE.
Jan 13, 2009 | Roper RGS7646KQ Gas Dryer
ROPER DRYER WILL NOT HEAT
Put the back panel back, and hope you havent done permanent damage
the back does not come off roper dryers for service
the front does
the back panel serves solely as a mounting point for important fixtures
there is no reset button
there are thermal fuses, if the thermal fuse, mounted on the exhaust duct or fan housing has failed, it must be replaced, but they are not expensive
look like this de074eb.jpgbcb6b5f.jpg to access the dryer mechanism
unplug dryer
remove lint filter
remove 2 screws under lint filter
with putty knife or other blunt blade, depress spring catches at front corners of top cover
raise front cover
remove 1 screw each side of front panel 1/3 from top
remove door switch wires
remove front panel set aside
test all thermostats heater and thermal fuse with ohmmeter, remove 1 wire test for conduct replace wire, no conduct replace
the local parts store will have the part, labelled whirlpool, ~$14 for thermal fuse, ~$40 if heater
examine rear panel reinstall any thing that is dismounted
while the dryer is open
Clean the lint out of fan, fan housing, ducts
airflow blockage is the 99% cause of thermal fuse blowing, some lint always gets past the lint screen
Oct 29, 2008 | Kenmore 63942 Dryer
Roper REX4634KQ Electric Dryer Logo
121 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
