Question about Mtd LAWN MOWER PART # 753-05201 SERVICE KIT:DECK 2
MTD 50" belt problem
I have an YardMan 22HP 50" cut Hydrostatic that has thrown the "secondary belt on the mower deck. It did this last week and I was able to coax it back on. After mowing for about 45 min today it came off again. When I checked it out it looks like it has about 6 or 7 inches of slack. The belt is in good shape it almost looks like I'm missing a pulley.
  • 246 Answers
Hello:
There May be a Pulley that the Belt is Not Routed onto.
Use the Breakdown at the Following Site Addy to Locate the Deck and Belt Routing Breakdown.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Have a Yardman 42in cut 16hp,Model #13AV604G671 can anyone tell me the drive belt part # please. Com says no such model ?
Hi,have just bought one and the number of the one which arrived is as follows #cama heavy duty belts part No.78-3896
Jan 08, 2013 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Jul 02, 2009 | Mtd Garden
Mtd LAWN MOWER PART # 753-05201 SERVICE KIT:DECK 2 Logo
514 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
