Question about Hardware & Accessories
Nelson lawn sprinkler timer will not turn on different zones
  • 2 more comments
  • michaelkhall May 09, 2009
    nelson smart zone tm ez
    yes on just starting with having problem, no on any changes, no it isn't in manual mode
  • Dan C May 11, 2010
    http://www.lawnh2o.com/nelson/PDF/smart_...
    Is this the same unit?
    Page 25 has troubleshooting instructions.
    First thing is to check that it has ac power available (should be an indicator on the lcd).
    Has it just started having the problem? did anyone change things? Is it in a manual mode?
    Can you be more descriptive of the model of timer, when it stopped working, etc.?
    Scholar:
  • 93 Answers
Assuming that you have AC power (the symbol is not on to tell you it isn't failed), and everything else seems normal, then open it up and make sure the ribbon cable didn't come out (sometimes temperature variations make the clips creep apart and do weird things), and that the sensor connection is secure (either jumpered or connected to the sensor input). Look for corrosion or water in the box. Do you have electronics repair skills? If not, the best you are going to do is replace the main components until it works. The replaceable parts are listed in the manual (the front panel seems to be working, leaving the ribbon cable(not likely) and the main board.) You also have the possibility that some of the valves were fried by lightning or something, and possibly the drivers in the board.
Posted on May 09, 2009
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
I need to order gears for Nelson Sprinklers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 03, 2011 | Nelson Sprinkler: Traveling Tractor
Where can I order the Nelson Sprinkler Traveling Tractor?
Check this out they also sell new...
heatman101
Apr 28, 2011 | Nelson Sprinkler: Traveling Tractor
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
Need replacement gears for Nelson sprinkler. Can you help
heatman101
Apr 16, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Nelson travelling sprinkler. I have lost the stop device. Can I get another one?
heatman101
Apr 14, 2011 | Nelson Sprinkler: Traveling Tractor
Need replace ramp for Nelson Raintrain 1865 traveling sprinklers
heatman101
Aug 20, 2010 | Nelson Sprinkler: Traveling Tractor
My nelson lawn tractor won't move forward in low or high gear.
heatman101
Aug 13, 2010 | Nelson Sprinkler: Traveling Tractor
My 1950`s Nelson tractor sprinkler has stopped running altogether. No water coming out anywhere.
heatman101
Aug 10, 2010 | Nelson Sprinkler: Traveling Tractor
Hardware & Accessories Logo
808 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
