Question about Car Audio & Video
Fuse keeps blowing
10 amp fuse in back of radio blows as soon as it touchs terminals.
  • 6,784 Answers
This will happen when there is a hot wire touching within the wiring scheme or, it could be merging circuitry within the radios main circuit board, which is mainly heat related and will happen over a long period of usage.
I recommend running a complete wire check form the radio and o the amp and all speakers. check the main radio wire harness for worn or lose connectors. make sure the ground is secure and the hot wire isn't crossing.
In most cases, this will be caused by merging circuits within the radio itself.if this is the case, you will have to replace the radio.
Please rat and have a great weekend:)
Posted on May 09, 2009
1970 volkswagen beetle, my #1 fuse keeps blowing. I am using an 8 amp as suggested, but as soon as i put it in and turn the car on it pops. Any suggestions?
Hey Kellan,
I would try to find out WHY the fuse is blowing.. but... you might try a 10 amp.. BUT NO MORE.... if the 10 amp blows right away... you MUST find out why they are blowing...
Check battery connections, ignition switch, any where the main wiring is passing through the firewall, or anywhere the harness is reduced through tight spaces...
Sep 22, 2017 | Volkswagen Cars & Trucks
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Mar 18, 2014 | Radio Shack Audio Players & Recorders
Radio amp fuse blows
problem could be radio.10 amp fuse for ignition switch power up radio display the 30 amp fuse for radio amp system in which that circuit hot at all times.
Nov 18, 2013 | 1998 Lincoln Continental
I have a Peavey Cs 400 amp that keeps blowing the 4amp fuse as soon as I turn it on any ideas
Fuses blow when there's an overload. This is usually caused by a transistor or IC that has shorted. You should look to the main amp as the most likely cause. If the main amp has transistors, then a test with an ohmmeter will show the faulty part. Connecting across the terminals will show the same as when you touch the test probes together. If you don't see a hole in the part first!
Oct 17, 2013 | Audio Players & Recorders
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
I have a dual XIA3145 580 watt amp that keeps blowing fuses
Generally, this indicates that there's at least one shorted output transistor.
Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still blows the fuses, the amp almost certainly has shorted output transistors and will need to be repaired.
I'd recommend using two 10 amp fuses. The amp will power up with 10 amp fuses if there is no problem. If there is a problem, there's less of a chance of doing more damage by using the 10 amp fuses.
Let me know if you have any other questions.
babin_perry@yahoo.com
Sep 04, 2009 | Dual Electronics illumiNITE XIA3145 Car...
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
