Question about Crosley CDE6000 Electric Dryer
Dryer i have a crosley dryer and it was working and i went to check it it had stopped wont come back on checked the connections and the breakers and everything what else can i do
  • 3 more comments
  • ang425 Oct 14, 2007
    could it be the timer cuz when i turn it on and feel the knob i can feel it tickin
  • ang425 Oct 15, 2007
    yes all that is fine
    i don't know where those things are
  • Anonymous Dec 27, 2007
    I have a crosley cde6500w dryer and it was working fine. but now it will heat up but it is not spinning and the light will not come on. can you help me.
  • jujuhoney May 25, 2008
    i have a crosley heavy duty gas dryer that i just bought from some dude, got it home it was working great for about two days, then the heat stopped. it still blows air just no heat on any cycle
  • 291 Answers
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
Posted on Oct 14, 2007
  • 1 more comment
  • Mike Johnson
    Mike Johnson Oct 15, 2007
    Did you check and see IF you had the volts and the cord connection at the dryer?????
  • Mike Johnson
    Did u check themostates, hi limit fuse and heaters?
  • Mike Johnson
    Have u took the front off the dryer yet and even looked for any of the things i mention in the post?
My crosley dryer (model# CED137SXQ0)made a loud ugly noise and stopped working i tried turning back on but it doesnt come on or make any noise.
check to see if the drive belt is broken. check out this video:
http://www.repairclinic.com/PartDetail/b171p8/Crosley-Dryer-Drive-Belt/341241/529597?modelNumber=CED137SXQ0&ss=a8b171d1287209&mr=1#repairHelpVideoTabs
Aug 04, 2015 | Crosley Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
I have tried everything , check breaker, check fuse nothing helps why wont my dryer turn on?
check your cord or plug ,
check the dryer switch,
or check the fuse inside of your dryer.
Mar 07, 2011 | Crosley CDE6000 Electric Dryer
Dryer stop working
Check the breaker for the dryer power. The breaker may have tripped or lost half of the power supply.
Sep 24, 2009 | Dryers
My crosley dryer stopped in the middle of a load and now it will not turn back on!!!
if it's an electric dryer, it may have tripped the circuit breaker.
Jul 20, 2009 | Crosley Dryers
Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
May 26, 2009 | Crosley CDE6000 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Crosley Dryer won't start
https://www.partselect.com/Models/CDE22B6V/Manufacturer/1/
This could be one of several things. There is a switch connected to the belt on the drum and if the belt slips of breaks the dryer wont start. There is also a possibility the timer is worn out
Oct 22, 2017 | Dryers
Just Stopped Working
Use a putty knife and press against those spring clips holding down the top.f23fbc9.jpg
Check the door switch for continuity. Let me know.
May 08, 2008 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
82 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
