Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
My WD5000h1u Lost it's power adaptor; can someone tell me what the voltage, current and polarity of the adaptor? Thanks!
  • 181 Answers
It is 12 volts dc and the center pin is positive and it is 500ma
Posted on May 29, 2009
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
Can someone help with the DC Volt, amperage and polarity of Altec Lansing 120i speakers please. I lost mine. Thanks.
Polarity and V are usually indicated somewhere near the plug. If not open the one with the plug, look at the wires connected to it, usually black and red, if still not clear follow one of the wires to the first connection point, if its to an electrolytic cap, the caps polarity will tell you what the polarity is at that input, the plug will be the same. The amperage really doesn't matter unless its too low, it can be much higher then rated, since trahsformers are self regulating for amperage.
Aug 07, 2014 | Altec Lansing 120i Computer Speakers
I have lost my AC Adapter (HDAD15W101-124) to operate my Medion life USB 2.0 colour flatbed scanner. Can I use a different adapter?
There are a few items that are important when trying to substitute an adapter. Obviously the connector must fit. After that, it is not so much the input voltage/current that is important, but rather the output/voltage/current as well as polarity. The output voltage of the adapter must match the device's requirements. The output current of the adapter must be at least as much as the device requires. Lastly, and most important, the polarity of the connector MUST MATCH, otherwise smoke and flames will occur. On round connectors, most devices have the positive terminal in the center (but mot all).
Aug 02, 2014 | Office Equipment & Supplies
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
I can't determine the polarity of my GPX PDL705 portable dvd
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
Dec 05, 2008 | GPX PDL705
Won't work
oh no maybe you used different adaptor some adaptor have reverse polarity. check the adaptor before plugging it..if you using variable voltage set to 3v then adjust also the polarity. the polarity should match the polarity of your camera.
Feb 05, 2008 | Kodak EasyShare C875 Digital Camera
Visioneer 5800 power supply
My power supply for my Visoneer 5800 appears to just have kicked the bucket... And, I stumbled across your post in a search for a replacement.
Anyhow, here are the specs off mine:
YHI Power Adaptor
Model: YS-1015-U12
Input: 100-120V 60HZ, 0.45A
Output: +12VDC/1.25A
Dec 16, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
1-866-400-5168
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
1,250 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
