Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Bottom of dishwasher leaks even after the last rinse water has been drained
The dishwasher works fine. the problem is afterwards,and unit is off, the bottom leaks.
  • spelrut May 09, 2009
    thank you. Can you tell me how to check out the rubber seals and gaskets? Does the bottom come off somehow?
Need a dwg on how to plumb a dishwasher
Posted on Jun 04, 2009
  • 67 Answers
If it is the bottom then look at rubber seals and gaskets which can be replaced. If it is not that then probably rusted through and time for a new unit. Also feel around hoses to see if water indicates a loose clamp on a hose or a leak in one.
Make sure it is not the bottom of the rubber seals on door which is relatively cheap too replace through manufacturer.
Posted on May 09, 2009
  • Bruce McLeod
    Bruce McLeod May 09, 2009
    This may help you - Buddy777
    Motor and Water-Related RepairsKeeping the dishwasher's sprayer arms, strainers, and water pump clean will help deter problems before they begin. Here's how to check on these important features.
    Cleaning Sprayer Arms
    The sprayer arms seldom cause any trouble, but sometimes the spray holes in the arms become encrusted with detergent or minerals. When this happens, the holes must be cleaned out so that the arms will work efficiently. Remove the lower arm by twisting off the cap that holds it to the motor shaft. Wash it thoroughly with water and mild household detergent. Sharpen a lead pencil and break off the lead point. Use the tapered end of the pencil to **** out the holes. A wood manicure stick can also be used.
    Do not use toothpicks, matches, or metal objects for this job. Lightweight wooden sticks could break off in the ports, causing blockage; metal could scrape and enlarge the ports. After cleaning, place the sprayer arm back on the motor shaft and twist the cap back on to hold it in place. Follow the same procedure to clean the upper sprayer arm.
    Removing and Cleaning the Strainer
    The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
    Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
    ©2006 Publications International, Ltd.
    A clogged strainer can cause the dishwasher to flood or overfill. Clean the
    strainer regularly, or after each load of dishes is washed.
    Troubleshooting Leaks
    If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
    Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
    Servicing the Water Pump
    In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
    Step 1: Remove the cap that holds the sprayer arm on.
    Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
    Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
    Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
    Step 5: Reassemble the pump, keeping the parts in order.
    To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
    On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
    Repairing the Motor
    If the dishwasher motor malfunctions, don't try to fix it yourself. Call a professional service person to make repairs or replace the motor. Before you call for service, however, you should check to make sure that the timer is working and that the dishwasher is receiving power.
    Don't let water leaks, a noisy cycle, soap spots, or other problems keep you from using your dishwasher. Most problems can be handled yourself if you follow the guidelines mentioned in this article.
General Electric dishwasher model potscrubber 1410 will not pump out final rinse water
So due to this water is still left in the bottom correct? you would have to remove the drain line where it connects into the sink area and also check inside the hole that the hose connects into the sink for any blockages if there are none found here then you would deinstall the dishwasher pull the unit out and check where the drain line connects to the pump. If you also found nothing in the other end of the line then you would disconnect the pump and assure nothing is stuck in the pump and that the impellar can spin freely. lastly you would reassemble the pump and drain hose but you would drain the unit into a bucket and still have the unit pulled out then start the dishwasher and assure there are no leaks. IF you have any further questions message me back Thanks Rick
Sep 25, 2011 | Dishwashers
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
For over six months our dishes (especially glass and china) aare covered in a gritty, darkish material. We often have to rewqsh or hand-wah these items afterwards. We have tried numerous rinse additives,...
i would guess that you run out of hot water in your house pretty quickly. if so, your water heater tank needs drained. hook a hose to the bottom outlet on the tank. shut off the cold water supply to the tank. open up the hot water on a nearby sink. drain the tank into a sump or a drain or a bucket that is lower than the tank. it will cost you 40 or 50 gallons of water, but it should clear up the sediment that you see floating in your hot water supply. you might have to do it twice. good luck
Nov 01, 2009 | Dishwashers
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Whirlpool dishwasher first 5 years ok last year thermal fuse - again last week - 4 cycles later - at rinse leaves water in bottom but dishes are cleaqn Rob
Your drain is gummed up and it may be the hose too. First remove the trays. Then, clean out everything from the bottom of the inside dishwasher pan. Also clear the drain hole in it. BE CAREFUL THAT YOU DO NOT CUT YOUR SELF ON ANY BROKEN GLASS THAT MAY BE IN THE BOTTOM. Next, go under your sink (or where ever the hose hooks your dishwasher into your drain) remove the hose and clean around both sides of the connections (be sure to replace it exactly how it was to prevent leaks-also check for leaks during and after your first test run). Lastly, run the washer empty using only 1/4 of vinegar. Hope this helps!
Mar 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Fridgidaire FDB126RBS2 Won't Drain in Rinse Cycle
check the drain pump for foreign object in the pump if nothing is found replace the pump
Apr 25, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Kenmore Dishwashing not working properly.
First off check to see if the drain hose is clogged where it meets the sink drain. 9x out of 10 this is the problem. Then remove the grate cover for the drain under the bottom rack at the back of the unit and check for lost utensils, broken glass, food residue, etc... If these are fine, then it sounds like a clog in the drain line at the water pump or a possible problem with the water pump, as long as it IS cycling right and there are no missed steps along the way (i.e. the last drain cycle before the rinse doesn't kick in and therefor uses the wash water as rinse water). The water pump is under the unit, so you will have to pull it out of it's hole. Remove the bottom panel under the door, remove the box cover on either the right or left hand side AFTER YOU FLIP THE BREAKER FOR IT and remove the wirenuts and free the line from the unit, and turn off water valve under the sink and unhook from the solenoid valve under the unit, and finally remove the drain again from the sink. Pull out of hole by finagling and sheer willpower LOL making sure you stop every once in a while to feed the drain hose back through the hole in your cabinet. You will have to split (take apart) the case of the water pump after you remove it from the unit and check the impeller for wear and to make sure it creates a good seal against housing and make sure the diverter engages properly and diverts water to the specified port (wash or drain) in the correct cycle. You may have to use an old extension cord, cut off the receptacle and hook up wires so you can work this outside. Should cure up any problem. Hope this helps.
Jan 27, 2008 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
442 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
