Question about Sony STR-DG600 Receiver
My Sony STR-DG600 Receiver constantly goes into Protect Mode when using FM or XM.
  • tford29 May 10, 2009
    Fixed it! It was a speaker overload issue. I ran all of the speakers through a Monster speaker box and it works like a gem. Thanks.
  • 757 Answers
Check to see if the antenna is firmly connected and not making contact with the receiver chassis or other inputs/outputs.
Posted on May 09, 2009
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Sony STR-DG600 ticking sound defect bug. There
Replace the IC 1101 with Part No. 6-806-144-01. This Ic will have updated software on board to fix the problem.
Mar 27, 2010 | Sony STR-DE597 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
Display dims on certain menu items
The display will dim for certain features that are not available for use in your current configuration or current operation.
For example; if you do not have an antenna plugged in then the selection for the tuner will be dimmed on the display.
Oct 26, 2007 | Sony STR-DG600 Receiver
Sony STR-DG600 Receiver Logo
394 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
