What is the a/c cap. on my 99 1 tonp/u?
What is the a/c capiacty on my 1 to chevy p/u?
  • 163 Answers
Just fill until you see the suction line on compressor sweating and she starts coolin good. Your pressures should read about 35-40 on low side and about 65-75 on high side. It depens on the ambient temp. Make sure you pull a good vacuum before you charge. Purge all the lines as to not get any air into system. Hope this helps.
Posted on May 09, 2009
Where is the radiator on a 99 Chevy Malibu?
Their is no radiator cap that goes directly into radiator. if you do plan on putting barr's leak in it just put it in the coolent tank on the passenger side that is the only way.
Feb 05, 2013 | 1999 Chevrolet Malibu
How do set time on 99 chevy blazer vortec v6 4.3
That could be correct, or 180 degrees off. Top dead center on the crank shaft can be on the intake or exhaust stroke.
Aug 25, 2012 | Cars & Trucks
1999 chevy blazer not starting
Check the plug wire from the ignition coil to the distributor cap.
If you haven't already, replace the distributor cap and rotor.
The GM Vortec's have issues with moisture getting inside the cap and rotor and causing problems.
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_00b31cc8f593773a
Apr 24, 2012 | 1999 Chevrolet Blazer
Why wont my 99 chevy blazer temperature warm up?
You may have vapour lock in your heater lines. Start engine, put heat lever on high, disconnect one of the lines on your heater core, the one on the flow out side, & see if you have any air coming out. Once antifreese comes out stick line back on & retighten clamp. Make sure your cooling system is topped off. Also your water pump may not be functionihg to it's maximum. Take rad cap off cold & view flow rate. If inadequate you may have to replace the water pump. Good luck!
Dec 09, 2009 | 1999 Chevrolet Blazer
Spark plug order to distributor
For a 1985 Chevy S10 with a 2.8L engine the firing order is: 1-2-3-4-5-6 The Distributor rotation is clockwise.Take off the cap and bump engine till the rotor points to the no. 1 plug. this is the no.1 contact on the cap. follow rotation around the cap in order. {ie. 2,3,4 ect.} hope this helps.
Oct 12, 2009 | 1985 Chevrolet Chevy
99 chevy truck 5.7 no spark
Check the distributor cap. The "spider" caps on the newer chevy's are notorious for going bad. Hope this helps! ~Derek~
Jun 20, 2009 | 1999 Chevrolet Silverado 1500
99 dodge intrepid specs
Inner main bearing cap bolts:
Torque to 15 ft-lbs, then rotate an additional 1/4 turn
Outer main (windage tray) bearing cap bolts:
Torque to 20 ft-lbs, then rotate an additional 1/4 turn
Main bearing cap cross bolts:
Torque to 250 in-lbs or 20.83 ft-lbs
Connecting road bearing cap nuts:
Apr 21, 2009 | 1999 Dodge Intrepid
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
