Question about Garden
I have a titan pro power waser the 7hp version diesel motor.I cant get it to take a feed from the detergent i want to use! any ideas??
I have the exact same machine and had the same problem. If you've tried running the washer with a water tank as the source, you will know that it needs at least some level of pressure - i.e. the water tank needs to be higher than the washer. The detergent input supposedly work by dropping the little feed hose in detergent.... it doesn't. This needs rigging up with a fixed hose from a container higher up than the washer to create some pressure. Don't forget to put an air escape hole in the top of the container or the liquid won't drop.
I also found the battery on this model needs recharging frequently, at least once a month if used daily. Keep a check on the oil cos when the engine oil gets too low the electric starter won't start it - it acts as though the starter motor is dead, just top up the oil. Always disconnect the hoses and drain them and the machine to increase lifespan. The hoses are only hydraulic hoses meant for hydraulic fluid i.e. oil, so water degrades them over time. Errr... keep the quick release fittings lubricated or they seize up. Can't think of much else.... they work rather well for the money but could do with a properly written English manual rather than a Chinese translation with information all over the place, and none of the above mentioned.
Posted on Jul 14, 2009
    Problem Solver:
I have a titan pro 3600psi i cant find where to buy the parts for it i need a 15 metre pressure hose and a unloader vavle cap can any one help
Posted on Jul 18, 2009
Lm looking for diesel solonoid for mazda titan track Chassis NO WHF5T100697 Engine NO TF175352
not sure of the year of that titan
a diesel solenoid humm confused ?
i cant see WHF5T100697 in this parts link?
parts might be discontinued or something strange
https://partsworld.co.nz/parts/mazda/titan
a mazda titan diesel starter solenoid any year
can be found online
Oct 27, 2016 | Mazda Cars & Trucks
Mazda diesel problems
check the fuel pump fuse and then the fuel solonoid for power and if power is pressent then check if solonoid is working if all is good then just crack each of the 17 mm nuts on ijector pipes to injectors and when fuel starts to bleed through then tighten
Dec 30, 2013 | Cars & Trucks
What oil do i need to use in my titan 6500 diesel generator?
a standard diesel graded motor oil is ok to use in these like 10w40 sj/a2 will be just right
Aug 07, 2010 | Garden
Detergent Dispenser Will Not Open During Cycles
most whirlpool built dishwashers with an electronic display will have a control board. off the control will feed the wires that run the dispenser. it uses 120v to operate a wax motor. a little orangish/red colored motor. two wires conect to it. since you cant really select a dispense cycle. the way i check them is to jump a cord to a surge protected power strip. energizing the wax motor with a jumper cord. see if dispensor opens. this may require more than an average amount of knowlege of electrical saftey when doing this. i always wire it up turn off surge protector then plug in and check. once done checking turn surge protector off and unplug.
Aug 01, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Just looked at 2000 coast spa hot tub with 1 6.5hp motor,is this enough power to support the 30 jets as opposed to another hot tub that has 2 7hp motors with 40 jets
a 6.5hp motor produces quite a bit of force. It should be able to support 30 jets just fine. Most spas range from 2hp to 7hp. Depending on your preferences, the 6.5 should be plenty but if you really want a powerful therapy jet, two 7hp pumps should be more than sufficient. They will also kick your electric meter up a few notches...
Two pumps give you more options, you don't have to have half of the jets turned off so one area can have more power, the dual pumps give you the option to run nearly all of the jets at the same time if you have more than just a couple people in the spa a once.
Nov 09, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Apr 14, 2009 | Dishwashers
Need to replace calypso washer...sugestions
The mold problem is from too much detergent usage.  Manufacturers recommend only 2 tablespoons of detergent per wash to avoid any mold issues.  It may not say it in the owners manual but it is from the manufacturers themselves.
Jul 18, 2008 | LG WM2688HWM TROMM SteamWasher
Paper will not feed
My OfficeJet Pro K550 makes sounds like it is getting ready to pick-up the Paper but sounds stops and Printer goes back into the ready mode without printing.
Will you please give me some pointers????
Nov 21, 2007 | HP OfficeJet Pro k550 Printer
Garden Logo
559 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
