I installed hz311 truzone but the fan wont turn on on heat even when i put it on auto or on. but it works fine when i put it on cool. also notice it shows it calling on heat on the zones but the fan wont turn on
  • 158 Answers
The main PCB board is defective
Posted on May 10, 2009
  • WTFWentWrong May 08, 2012
    I have the same problem.. Does that me mean the PCB of the HZ311 is bad? Thanks for your help..
In the zoning system cooling does not get turned off automatically
If the blower not turning off or is the condenser not turning off. Are ALL ZONES satisfied? Is fan in auto position at all zones?
Jul 04, 2017 | Honeywell Heating & Cooling
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
White rodgers thermostat
Does the indoor fan run with a call for cooling ?
Dec 06, 2017 | Heating & Cooling
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
2004 vw passat a/c fan wont turn on
There may be a defective fan control switch.
May 25, 2017 | 2004 Volkswagen Passat
Gmp 100-3 fan runs even when tstat is set to off an fan setting to auto. unit ran fine all summer in cool mode and was off for the last couple weeks. just notice the fan was on yeaterday. ran unit in...
Hello, one way to check is remove the green wire from the G termimal on the circuit board in the Furnace, if tn
His turns it off it may be a short in the tstat wiring or bad thermostat, if it does not turn it off the relay on tne control board is stuck and tne entire board must be replaced.
Sep 28, 2011 | Goodman GMS90703BXA Heater
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
We gave a Goodmn Hertz 60 Phase I heat pump - installed this summer....worked great for cooling..now that temps are dropping we are needing heat. When we turn it on it comes on but never heats. Think it...
If you changed the unit but didn't change the thermostat it is possible that the thermostat that you have will not work with that unit. I see that the unit you installed is a heat pump, you may have a straight cool T-Stat. If you put the T-Stat in the "Auto" "Heat" mode the outdoor fan and the compressor should be workng as well as the blower fan. If it turns out that the outdoor fan and compressor are not running you will want to buy a Thernostat that is compatable with heatpumps should be 2 heat/ 1 cool
Nov 05, 2010 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
