Question about ASUS Eee PC 900 16G Notebook
Asus update and system update
Asus update system update
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I want to update my P4BG-VM asus m.board bios update
Please go to this site and select your operating system. Your bios update options will be listed under the bios drop-down. Hope this helps.
May 22, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I want to update my Asus A8V-VM Bios...model: A8V-VM version:0401 chipset:ATHLON64 Date: 6/19/2006. where do I get updates please help.
Normal 0
You can download the BIOS updates and drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Oct 07, 2010 | ASUS A8V-VM Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Bios asus P5S800VM,rom
Try Updating your System Bios from
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5S800-VM
Version 1023
Update Procedure:-
1. Copy the ROM file in a pen drive
2.connect the Pen drive to the usb port of your Motherboard
3. Restart your m/c and press Del Key and Enter Setup
4. Go to
ASUS EZ Flash and update the Bios.
Jun 06, 2010 | ASUS P5S800-VM Motherboard
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
Mar 29, 2009 | ASUS P4PE-BP Motherboard
Asus gps A696
If it has a driver for Macintosh Computer then you can update it. or update it through Windows System be sure to install first the driver.
Oct 15, 2008 | ASUS MyPal A696 GPS Receiver
ASUS Eee PC 900 16G Notebook Logo
205 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
