Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Faulty USB module on inverter board
20" viewsonic monitor...has a small USB module plugged into the inverter board to allow Usb connections to the monitor. I have the same problem on both 20" monitors. The module is faulty...it pulls the 3.3 Volts to ground. Any chance of me getting a replacement? DAL0VPUB012 Rev.A A3C 22l0VPUB005 are the numbers on the module. Thanks for your time and concern. moefo56@yahoo.ca
gymowner
  • 679 Answers
SOURCE: backlit problem with ViewSonic VE150m (Beige)
I had a problem with one of my viewsonics, and called their tech support, they gave me an RMA number once I explained a similar problem to them and fixed it for free. It sounds like it needs a power board, but if you call Viewsonic they will fix it for you for free. They may ask for you to pay the shipping one way, unless it's under a year old or more with extended warantee, they will take care of you, don't mess with it yourself, unless you are a tech yourself, once you start taking it apart that is the end of your service warantee with them, thanks
Posted on Dec 26, 2008
leroyal
  • 2120 Answers
SOURCE: Hello,
Try eBay for those parts.
Posted on Feb 20, 2009
bammbammfran
  • 159 Answers
SOURCE: viewsonic vx924 power/inverter board
See ebay item 390074135923
http://cgi.ebay.com/2-Inverter-transistor-viewsonic-VX910-VX924-DK-QB-QO-QA_W0QQitemZ390074135923
Fran
Posted on Jul 27, 2009
budmrtn
  • 11361 Answers
SOURCE: One of the tiny fuses
I replace the surface mounted fuse with axial-lead fuse, PICO fuse made by LITTLEFUSE. You can try using a 1 Ohms 1/2 watt flame proof resistor in place of the fuse, if the resistor get real hot and burnt up then it may have shorted Transistors or transformer. You can get the number of the board and go to www.lcdparts.net to see if he has the inverter board in stock.
http://s807.photobucket.com/albums/yy352/budm/PICO%20fuse%20by%20Littlefuse/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 04, 2010
budmrtn
  • 11361 Answers
SOURCE: ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Dec 02, 2010
Viewsonic va2026w no display
Viewsonic va2026w no display? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
ILPI 033 490901400100R 79090140 ViewSonic 790011400720R Power Supply...
Aug 11, 2012 | ViewSonic VA2026W 20 inch Monitor
E59670 repair
ic no e59670 acer power supplies
May 29, 2012 | Dell UltraSharp 1908FP Monitor
Screen is very dark (almost black) you can barely tell it is even turned on
The inverter has failed, its probably a small component on the inverter circuit board that's at fault. You need someone competent with a soldering iron and a new component or circuit board or a new monitor.
Dec 20, 2010 | ViewSonic VE710b 17" Flat Panel LCD...
HOW do I open the Viewsonic VA703b - no visible screws etc - nothing happens when power is connected and i want to check internal caps and fuses etc.
http://www.givemefile.net/smanuals/monitors/viewsonic/va703b.html
here is the service manual. It says you can download it. Hope this helps.
Dec 15, 2010 | ViewSonic VA703B LCD Monitor
Dec 02, 2010 | ViewSonic VE170b 17" LCD Monitor
Turning on Microphone of Viewsonic VX2255 LCD Display
The microphone setup should be with the communication software that you will be using such as SKYPE or OoVoo set up panel. It will not be at the monitor. I use OOVOO because I can do video call with six people at once.
Jan 31, 2010 | ViewSonic VX2255 Monitor
The monitor blinks
That is a faulty inverter.
The inverter is an high voltage board that supply power to the back light lamp. In your case it is faulty and it is cutting power every now and then.
The part should be tested and replaced.
Mar 31, 2009 | ViewSonic OptiQuest Monitor
ViewSonic VX910 19" LCD...
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Apr 22, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
139 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
