How do I add the "+" sign to send an overseas tax?
I have a Sharp FO781 fax, and need to send an overseas fax. How do I get the ''+'' sign before the number please?
  • 1,959 Answers
There should be no need to get the (+) sign. Dialing 011 + country code + phone number should allow you to directly call the fax you're trying to reach. This link will explain the process as well as supply country codes. I hope this solves your problem. Best of luck to you.
http://www.q7c.com/travel/telephone.htm
Posted on May 09, 2009
How to change the tax rate on a Sharp EL-1801C calculator
Enter the desired number for the tax rate... followed by hitting the "STR" button... followed by hitting the "Tax+" button. Here is a link to the manual for the Sharp EL-1801C. http://bit.ly/lf3edL
Jun 19, 2011 | Office Equipment & Supplies
Tip
How to Fax From a BlackBerry(Email Account)?
<span> <p> <span> <span>Instructions</span></span> <ol> <li>Set up an email account on your BlackBerry. This can be a third party email account, such as Gmail, Hotmail or Yahoo. You can also use your BlackBerry email address.To set up an email account on your BlackBerry, press the "Berries" button from the home screen. Select "Settings," "Setup Wizard" and "Email Setup."</li> <li>Sign up for fax services through a company that allows you to send faxes through your email address.When signing up for the fax service, you will be required to enter your email address from step one.A few companies that allow you to send faxes through email are eFax, InterFax, SmartFax and RapidFax. You will generally be charged a fee to use the service.The exact fee will vary by provider.</li> <li>Open your email account on your BlackBerry.Press the "Berries" button.Select the option to compose a new message.Enter into the "Body" section of the email message, the information you would like to appear on the fax cover sheet.</li> <li>Press your "Berries" button. Select the option to add an attachment. Scroll through your phone files to select the document you would like to fax.</li> <li> <p>Enter the recipient's fax number in the "To" field." Behind the recipients fax number, include the domain information for your fax service provider. For example, you will enter "123456789@yourfaxprovider.com." Select the "Send" option to send your fax.<br /></li></ol><br /></span>
on Mar 12, 2011 | Cell Phones
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
What is a Comm. error 2001?
This is an error message you get because of poor line conditions, this is common when sending overseas.
Please follow the directions below for sending overseas.
Press (Fax). Load your document.
Press up or down arrows to choose
Overseas Mode.
Press OK.
Press up or down arrows to choose On (or Off).
Press OK.
then dial number and press start.
Apr 12, 2010 | Brother MultiFunction Center MFC-440CN...
Brother mfc640cw
If you are having difficulty sending a fax overseas due to possible
interference on the phone line, we recommend that you turn on the
Overseas Mode. After you send a fax using this feature, the feature
will turn itself off.
1 If it is not illuminated in green, press (Fax).
2 Load your document.
3 Press Menu/Set, 2, 2, 7.
4 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
Your manual gives this information also on page 3-13
Good Luck
Dec 15, 2009 | Brother MFC-640CW All-In-One InkJet...
Need to send an overseas fax - how do I get the "+" sign before the fax no?
I don't know what you mean about a "+" sign. There is no sign necessary. For example: You can't do it on a regular telephone call either.
If you're having trouble figuring out the dialing codes, this link may help:
http://www.timeanddate.com/worldclock/dialing.html
May 09, 2009 | Office Equipment & Supplies
Sending an international fax with a brother fax machine
I'm thinking you did not specify 1 for long distance and international calling check the TX settings for international and long distance
Aug 23, 2008 | Brother Office Equipment & Supplies
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sending a fax from my L80 to an overseas fax machine.
overseas calls must use 011 then the country code 866 then teh city code then the fax number . Do not dial starting with a 1 otherwise you will be calling in North America
Sep 03, 2007 | Canon FAXPHONE L80 Laser
133 people viewed this question
jasbo
jasbo
