Home | Copiers | My margin gets cut off...
Copiers
Problem for Copiers
Generic problem for all Copiers
My margin gets cut off on one side whe...
By wandaloohoo on Oct 11, 2007
I have an AR-407 copier, and whenever I use the document feeder to make 8.5x14 sized copies, the side of each page gets cut off.  I have tried fiddling with the margin settings, but nothing seems to work.  Any suggestions?
Thank you so much for any help you can offer!
Comments:
Oct 16, 2007
Oh Inky, thank you so much for trying, but it doesn't seem to fix the problem....
Perhaps a simple solution is just not meant to be :(
Same Problem
Feb 08, 2008
-   My top margin gets cut off when copying a regular size original 8 1/2 x 11
Can someone email me at constancebaumeister@ionmedia.tv if there is a solution-   connieb
Solution #1
posted on Oct 11, 2007
Somewhat Helpful)
Inky
Rank: Wiz
Rating: 85%, 935 votes
Are you copying onto the same size of paper or onto another size like A4? If changing size you will have to tell the machine what sizes are in use.
If you are using similar sizes, try setting off a stack and as the machine feeds a sheet in, turn off the power. Lift the lid and see iff the page is running in the correct position and not off to one side. If the page is off to one side, you need to check that you have the paper guide (where fitted) pushed up to the correct position etc.
Let me know if this helps any.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
Why does the Sharp MX 4501N go into a "clear data" mode for over an hour? No printing or... (More)
Answer
I am trying to set up the printer remotely and would like to do it via web browser . Can I set up... (More)
Answer
folder error #17 how can i fix it?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
