Question about Whirlpool Dryers
1 Solution for "I have a whirlpool WED5520SQO
1 Solution for ''I have a whirlpool WED5520SQO dyer You hit the start button and nothing''
  • 6 Answers
SOURCE: my whirlpool dryer is dead
Most newer dryers have a thermal fuse link which prevents them from producing heat if it has overheated due to lint build up. Safety! Remove the back of the dryer after you unplug it of course. Look for a white, two connector, block about 1/4 by 1-1/2 inches, mounted to the back of the heat transfer duct. Remove both of the wires from the the connectors and test the fuse for continuity. Multi meter needed. This should show 0 Ohms. If there is no change on the meter than this fuse is bad. Most any appliance parts place will have in stock. $12 - $15 Clean out as much lint as posible from the exhaust opening with a vacuume and reinstall the back panel.
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Posted on Feb 17, 2010
SOURCE: my whirlpool duet dryer will not start. Power
Mine isn't stacked and I had the same problem. My husband and I just bought ours last week. I had to close the door and then press on the top of the door to hear another click and it then would start the cycle. I don't know if this is correct or not. I have searched whirlpool web site and not found mention of this. I am calling the department store we purchased ours from to see if this is normal. Hope this helps!
Posted on Mar 01, 2010
SOURCE: Our Whirlpool Dryer, model #
you have a starter button that went bad, you can order them from sears online
Posted on Aug 01, 2010
  • 29 Answers
SOURCE: kenmore gas dyer, model 11170092991.
Check the door switch first
Posted on Dec 03, 2011
Dyer will not start, timer is working but dyer does not start cycle
You either have a bad motor or start switch. You might also have a wiring problem.
May 05, 2012 | Dryers
Where is the the reset button on roper dyer
There is no reset button on any dryer. Your Roper is a Whirlpool with a different nametag. Depending on how old it is there may be 1 or 2 non resetable fuses. They are in the back behind the rear cover. They blow when there is another problem. Such as a clogged exhaust or a bad cycling thermostat. Don't do any work on it without double checking that the machine is unplugged
Nov 20, 2011 | Roper REX3614KW Electric Dryer
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
Hi
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itdoesntworkatall_electric
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
My whirlpool dryer is dead
Nov 20, 2008 | Whirlpool LER4634J Electric Dryer
Dryer won't start
Check the door switch, if the switch is bad the dyer thinks the door is open it will not start.
Apr 22, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
141 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
