Question about Acer Aspire 5500 5570-2609 Laptop
SD card reader driver required...
Need for SD card reader diver for Acer Aspier 5500 due to formating note book recently and the driver not fixed... Al-Asfoor asfoor44@msn.com
    Guru:
  • 830 Answers
You can safely download and install the driver from here:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-5500-Card-Reader-Driver-10604.shtml
You may need to register but it is free!
Posted on May 09, 2009
I have a acer Aspire Ei-571 laptop.I insert a sd card to it's card reader.sd card is a new one there arn't any files in that card. so when I insert the card to the reader I can't open it.so what do I need...
u more than likely need to format it first so your computer can read it.
see if it appears in windows explorer, if not copy a file then right click and send to the SD card and the option to format should appear, format it and this should fix your problem.
Oct 14, 2013 | Acer Aspire E1-571-6650 Laptop
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
Cannot access SD card containing photos. Initally tried to copy photos to hard drive but system seezed and cannot now access SD card, keeps asking do I want to format card, always said NO. Regards Bob from...
Hi Bob, can you tell me what SD card reader do you have? is it a internal one from a laptop?
Some of the older SD card readers doesnt read SDHC cards, you might want to check. And some just require new drivers for the SD card reader. Best way to check is look for your SD card reader's driver in DELL then using the maker name of that driver and go to their website to see if they have an updated driver. Dell usually doesn't have the latest drivers.
May 04, 2010 | Dell Computers & Internet
Will not open anything nothing happens at all when i plug in my sd card to laptop WHY??
If the device driver of the card reader is accurately installed. I suppose the auto run option is tuned of. You can manually open the card by opening the "My Computer" right clicking on the SD-card icon and chose open!
Wish you success
Bruce
Dec 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
My SD Card Reader Won't Work, Need A Solution
Go here:
http://support.acer-euro.com/drivers/notebook/ex_4620.html
(The US server seems to be having problems right now)
Download the XP cardreader 2.0.0.8 drivers, install them. There are three possibilities to your problem:
1. The reader is broken
2. The reader's driver is malfunctioning
3. The reader has an issue that might need new firmware
4. All your cards have become currupted somehow (a malfunctioning device[IE camera]] or other reader, this is highly unlikely though)
Try the driver first, then if that doesn't work, then a motherboard bios update might help(but beware, this is a dangerous procedure, I wouldn't try this unless the update documentation specifically stated that it fixed an issue with the reader). I don't see an update for the firmware of the reader itself, so hopefully it doesn't need one.
Good luck
Mar 14, 2009 | HP Pavilion ZV6000 Laptop
Unable to transfer photos from my usb sd card reader, I/O device error keeps coming up? i am running vista on a compaq f765ea
This is due to cable not installed properly pleace check the cable abd then try again.
NOTE: Make sure that u have installed all the drivers required for connecting usb and card reader is connected properly.
Aug 16, 2008 | Compaq Computers & Internet
SD Card Reader Not Working on Acer Aspire 5600 Laptop
i changed my hard drive .. and my computer has an SD slot .. but it wont read my card when i insert it .. odes it have to do with the new hard drive .. what can i do ..
Dec 06, 2007 | Acer Aspire 5610-4648 Notebook
Card reader in aspire 5570z
OK guys, I fixed this problem....here is the link the driver for the aspire 5020 card reader works on the 5570z and works perfectly...please rate me enjoy..here the link..click on MS WINDOWS XP drives and click on Cardreader TI7421
http://support.acer-euro.com/drivers/notebook/as_5020.html
Oct 30, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
304 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
