Question about Compaq Presario V4000 Notebook
Internet connection i have just formated my laptop and reinstalled windows. when i used to turn my laptop on it automatically detected my router and the internet came on since ive formated my laptop i cant connect to internet it sats no connection can u help please
    Scholar:
  • 151 Answers
After installing your OS install Ethernet adapter.
It's setup comes along with the motherboard cd that is given to u ...when u bought ur laptop.
Posted on Oct 11, 2007
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
Jul 18, 2011 | Belkin Basic Wireless Router
My laptop can not display webpage on the internet explorer
Check to see if you have internet connection with other laptop or devices, secondly does internet work for other programs that uses internet like msn messenger. If it does work for other program and it's your browser that doesn't display then we got a proxy error issue. Other then that, it could firewall settings that is blocking you... But with the proxy issue, Open up the internet explorer, click the "Tools" bar on the top right side. Scroll down to "internet option", a window will pop up, go to the "connections" tab, click that, go down to "Lan setting" a window should pop up, set you automatic configuration to "automatic detection" If already is set, and you still get nothing.... try to see if internet explorer would work with another wifi network such as those public free wifi area. If that works, then your router setting has to be corrected in the router application. Could be a parental or client block.
Jan 24, 2011 | Acer Aspire One PC Notebook
Have connectvity on laptop through router but no internet. firewall off and ipconfig reset, but still no internet through ie or firefox?
Hello.
Could be a problem with your LAN card or interfering software, if others accessing your network are OK. (Test first). If others are experiencing the same, reset your router and contact your provider, if necessary.
Try these suggestions ... perform the next if each does not work:
Move your laptop next to the router to see if distance is a problem.
Connect your laptop to the router with an Ethernet cable to see if the wireless function is not working.
If you have an anti-virus software package installed, disable for testing purposes.
If you have installed / updated your computer and now Internet doesn't work (worked previously), remove or uninstall.
Go to Device Manager, find your LAN card and update the driver.
Go to Device Manager, delete the LAN card, reboot your laptop.
Hope these suggestions help.
Jan 21, 2010 | Compaq Presario R3000 Notebook
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
I have hooked it up as the instructions state but it will not find the internet, I am useing a hp laptop and am trying to go wireless, it is the vista system
No its not your windows system, try to check again your wireless router if the software firmware are installed properly in your PC. Also to configure it and connect your internet provider to the Router, which is automatically create its own Protocol Address or Obtain Address, even on Wireless connection. This is basic on Wireless Router to connect on the internet. Good luck!
Aug 04, 2009 | Linksys Wireless-N WRT150N Router
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
Laptop wireless connection
assuming you have set up the router to enable DHCP which automatically detects pc's and assigns an automatic ip address, and assuming you are using XP and not Vista, although the workthrough is similair; go to open internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked, then apply and exit IE
Next go to control panel>network connections, double click your wireless connection icon, select the TCP/IP line and click properties, then make sure obtain an ip address automatically is ticked, apply it ok, then open IE again and click the refresh button a few times.
Sep 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
My laptop says that it is connected to my wireless router but the router isn't connected to the internet what should i do to connect it?
If the router is turned ON then automatically your laptop wireless card will detect it and connect to the router.
To say in otherwords, now your notebook and Router are simple network.
You need to contact your router support to configure the router to get Internet. After automatically your notebook gets the Internet from the Router.
The above message is just by what I understood from your message.
If the issue is different, and if the router is already configured to Internet and if there are other systems connected to the router and able to access Internet, then replay back, so that I can explain accordingly
Aug 09, 2008 | Computers & Internet
D-Link DI-524 AirPlus G - Laptop Cannot Connect to the Internet
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
In the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Oct 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Internet connecting
The router does not have to be installed on your pc,
In the routers settings(type the routers ip address in your web browser, depending on the make) ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Oct 22, 2007 | Computers & Internet
Compaq Presario V4000 Notebook Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
