Ac not working in a 2004 corolla it has freon but compressor wont start
  • 163 Answers
Mabey not enough freon or the low pressure switch is malfunctioning. Jump the low pressure switch for just a little and see if this kicks it off. Once pressure switch is jumped turn ac off then back on. This will let enough pressure in system to get going or let you know the switch is bad. Hope this helps.
Posted on May 09, 2009
  • cheap repair Aug 22, 2011
    replace AC compressor clutch relay and service the cabin air filter
2004 toyota corolla ac stopped working
First make sure you have freon..
when you turn it on do you hear a faint "single click"?? If you don't, switch your horn relay with the compressor relay. This may work.
Feb 25, 2014 | Apple iPod touch Second Gen (8 GB,...
2004 kia sedona ex ac not working can jump ac
You could have several problems. If your pressure readings (freon) are low it will not kick on the clutch for the compressor. Do you happen to know what your pressure readings are when you do jump it or what they are (low or high pressure side) when it isn't engauged? Also you could be dealing with a relay or a sensor that detects your pressure readings. Really knowing your pressure readings would be a start before I can begin to help.
Sep 03, 2013 | 2002 Kia Sedona
85 corolla ae82 sedan 5 speed... I'm not getting
do you have freon in the system because the low pressure switch will not let the compressor run with out enough freon dont know where the switch is but it should be near the dryer there is also a diode in the harness going to the compressor
Aug 12, 2013 | Cars & Trucks
2004 matrix ac inop
Most of the Toyotas in your year range have an updated AC relay. If the system is full of freon, the pressure switches are operable, try replacing the relay.
If the system is low of freon, it won't allow the compressor to start up.
There is an easy way to check the compressor clutch, but I can't explain it unless you understand how a relay works and which pins to connect in the relay box.
Aug 07, 2012 | 2004 Toyota Matrix
A/C not cold on 2004 Toyota corolla. Compressor appears to working and we have added freon
if the clutch is turning on that fuse is good check the cooling fan if it doesn't work it will not cool the freon
Apr 27, 2012 | 2004 Toyota Corolla
Ac
the relay is there for a reason, ide start there
Mar 15, 2012 | 1993 Toyota Corolla
My AC is not blowing cool air. Compressor clutch is not getting engaged. AC button is showing green light indicator though. I am suspecting clutch relay problem. where is air conditioning clutch relay in...
First of all check the freon pressure, if the pressure is low the compressor clutch will not turn on. The pressure should be between 30-40 PSI.
Aug 25, 2011 | 2004 Toyota Corolla
The a/c on my 2004 Toyota Corolla is not cooling. It has 82,000 miles. Can you advise?
you may need to charge your a/c system. the freon will escape after while.
Mar 03, 2010 | 2004 Toyota Corolla
2004 Chevolet Silverado blows hot air and snowflake button blinks when pressed
Blinking or chattering of the compressor clutch usually indicates low "freon" charge.
Jul 09, 2009 | 2004 Chevrolet Silverado 2500HD
A/C wil not work
if your low on freon the unit will not work.low pressure switch cuts it off. or you have a bad a/c clutch asy.
Jun 12, 2009 | 2004 Hyundai Santa Fe
Heating & Cooling Logo
326 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
