Question about Delta Faucet Company Classic Collection Venetian Bronze Toe Operated Tub Dr
Delta tub tap only cold water no hot water or pressure for shower.
My all in one Delta tub tap .. we only get very little cold water ...no pressure for shower and no hot water.. this tub is never used.. what could be the problem?
  • 23 Answers
Take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
Posted on May 12, 2009
Delta 1400 tub faucet leaking hot water, how do I stop?
the cartridge inside is bad and needs to be replaced or at least cleaned in order to stop the water
Oct 24, 2010 | Delta Faucet Peerless& Tub And Shower...
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
The handle on the delta diverter will only go from cold to the ''12 o'clock'' position. It will not go over any further counter clockwiseto the hot side. Both shower tubs have this problem. Is there...
that is the way they are made. they are pressure balanced to reduce the risk of scallding.
however there is an adjustment that will allow a little more hot water. if you remove the handle, there is a small plastic disk, remove that, under that you will see a small ring with what looks like gear splines... pull out slightly and turn counter clockwise a few notches. reinstall the plastic disk and test.
if you don't get enough hot water, adjust again. only adjust a couple of notches at a time. you don't want to scald yourself in the shower.
Jun 01, 2010 | Delta RP17453SS Standard Diverter Tub...
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
May 05, 2010 | Delta Home
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
THE SCALDGUARD ALLOWS VERY LITTLE HOT WATER HOW TO CHANGE TO BEABLE TO FILL TUB I HAVE A DELTA#T13220 I CAN'T THE HANDLE OF EITHER
You probably need to adjust the faucet to give you hotter water.
The other problem can be low water pressure... if your cold water pressure is low or there is a restriction in the line, it willl also restrict the hot water flow.
Follow these instructions to pull the whole valve assembly out and check the water flow of the cold water with out anything in the valve body. This will tell you if the problem is in the piping of the valve.
http://www.everyfaucet.com/Delta-T13220-DLT2970.html
Page down to near the bottom and look for the PDF attachments. They will give you the details you need to take the faucer apart and amke the neccesary ajustments.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Delta & Single Handle Shower Faucet
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
Keeps running
Sounds like you need to replace the inner cartridge. You can shut your water off at the street meter if your whole house does not have its own external shut off. Be sure to relieve the pressure before popping out the cartridge.
Jan 16, 2009 | Delta T13420 Chrome Classic Single Handle...
Delta Faucet Company Classic Collection Venetian Bronze Toe Operated Tub Dr Logo
472 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
