Question about West Bend 82224 Buttermatic Popcorn Maker
I need instructions for using my buttermatic II 4 qt popper. How much oil and popcorn do I use? When do I put the popcorn in (at the same time as the oil)?
    New Friend:
I have one with the instructions. Its 1/4 vegetable oil and 1/2 or 2/3 cup popcorn. It says not to exceed 1/4 oil and not to use butter, margarine, or lard because it can smoke. It also says if using gormet popcorn, only use 1/2 cup to prevent cover from lifting. Hope this helps. :)
Posted on Apr 04, 2017
  • 1199 Answers
SOURCE: how much oil and popcorn do you need in the popper
single layer of popcorn on bottom of entire oil is needed but you can use a tablespoon if you like...butter melts through the hokes in lid....Place butter pats over top holes in lid before popping starts if you want butter to drip down on the corn ( it does pop better with a little oil!)
Posted on Dec 09, 2008
SOURCE: cord for stir crazy
Replacement cords can be found on the West Bend site:
Posted on May 22, 2008
SOURCE: Salton Popcorn popper Model# PCST22Y
I owned one of these and it worked for 2 whole months.
It's a popcorn machine, how hard could it be? Make sure the stirring bar it tight on it's shaft, make sure the plastic bolt is tight. Add about 2 tablespoons of vegetable oil, and 1/4 to 1/3 cup popcorn kernels. Turn the machine on. Turn the machine off when the popcorn stops popping, or you might scorch the popcorn.
Posted on Sep 01, 2008
  • 4 Answers
Go to website and click on West Bend icon
You can download an instruction manual under the replacement parts/popcorn poppers area.
Posted on Dec 27, 2008
SOURCE: 6 cup stir crazy popcorn popper lid
There are lids around your house that will fit this. Try a butter or sour cream lid.
Posted on Jan 20, 2009
Do you need to add anything to the popcorn machine
Depends on your machine. What bran/model dso you have? If it is an air popper, NO. Adding anything will damage the machine.
If your machine is not an air popper then you likely need to add some oil. I currently have a WestBend Stir Crazy Popcorn Popper. You use a tablespoon of oil for each 1/4 cup of popcorn in the bottom of the popper. See here; an instruction manual is available.
You are best to check with the manufacturer of your popccorn popper.
Jan 30, 2011 | Kitchen Appliances - Others
I purchased a nordic microwave popcorn maker and misplaced the directions for making the popcorn. I need to know how much popcorn to put in the bowl and amount of oil if any is to be used. I would...
The Nordicware Popcorn Popper is one that actually works in the microwave. The 3-Qt. Popper makes light and fluffy popcorn in about 4 minutes. Just place 1/2-cup of popcorn kernels in the bottom bowl and cover with the lid. No oil needed, makes up to 12 cups of popped corn. Good luck Richard
Nov 14, 2010 | Vacuums
I have two of your popcorn makers and lost instructions on the amounts of ingrediients. I need to know how much corn, oil and salt to put in aluminum popper thank yhou
The manual says to put 1 to 3 tablespoons of oil in the popper, and when hot, add 1/2 cup popcorn. Salt it after dumping the popped corn into a bowl.
Nov 11, 2010 | Back to Basics Popcorn Popper (PC6)...
I have the same popper and the instructions. You do not need any oil. There is a circle lid piece at the top of the popper. You put the pop corn seeds in that lid and then pour the seeds in through the hole at the top. The popper needs to be off while you do this. Once you've added the popcorn you can then turn on the switch located on the back of the popper. It looks like a small light switch. The popcorn will start popping and it may smell funny at first if you haven't used it or used it properly. You have to monitor it and turn it off yourself- using that same switch. And per the manual you need to wait 15 minutes before you use it again.
We use ours all the time and love it. Hope this helps.
Aug 21, 2010 | Nostalgia Electrics OFP501 Old-Fashioned...
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
No operating instructions
No oil needed - is hot air popper. Use round lid on top to measure popcorn, pour popcorn into metal part in center of popper.
Dec 24, 2009 | Nostalgia Electrics OFP501 Old-Fashioned...
The manual got missed placed can you tell me the amount of kernnels to use in it. It is a six qt. stir crazy popper
Place popper base on flat, dry surface. The heat-resistant base allows for safe table use.
Preparing Popcorn
There are two models of the Stir Crazy® Corn Popper, one for making up to 6-quarts and the second for making up to 8-quarts of popcorn. Listed below are the proper amounts of oil, corn and butter (or margarine) to use for making various amounts of popcorn. Do not attempt to make 8 quarts of popcorn in the 6-quart model.
Quarts of Popcorn
Amount of Oil
Amount of Corn
Amount of Butter
1 Tablespoon
⅓ Cup
1 Tablespoon
2 Tablespoons
⅔ Cup
2 Tablespoons
3 Tablespoons
1 Cup
3 Tablespoons
3 Tablespoons
1¼ Cups
3 Tablespoons
Here is the link to download the manual:
Oct 16, 2009 | West Bend 82306 Stir Crazy® Popcorn...
The usual way to use a pop corn popper is to:
1st - add oil
2nd - add popcorn
3rd - add any seasoning (if using the pre-packaged "theater" popcorn mix).
DO NOT add butter into the popper, as it will burn quickly and make for some foul tasting pop corn.
You can always add butter and salt to taste AFTER the pop corn is done popping.
Hope you find this Very Helpful. Best regards!
Aug 18, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
1,016 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
