Question about Briggs & Stratton Garden
My pressure is very erratic it dyes down completely then goes back up for a second then back down, also the engine seems to rev up and down with it
    President:
  • 2,559 Answers
Either the pump is low on oil or your seals need replaced.
Posted on May 09, 2009
My 2006 dodge ram 1500 4x4 mega cab 5.7 hemi has 234,000 miles runs good but it now has an oil leak. When I turn left or right while driving the oil pressure goes all the way down, the for back up after I...
Your engine won't run good much longer if you allow the oil level to get so low the pump sucks air on corners. The oil pressure dropping isn't a guide to how often the oil needs a top up. The idea is to top up before the oil pressure falls, probably checking and topping up weekly would be safer, at least until the leak is cured. In the old days only a fool wouldn't check the oil and water daily...
There are two ways to locate an oil leak. The first method is to wash the area around the leak and run the engine and watch using strong light and a mirror if necessary until fresh oil appears.
The second method is the high-tech method where a fluorescent dye is added to the engine oil and again the engine is run while a strong ultraviolet lamp illuminates the area until the dye appears.
May 29, 2017 | Cars & Trucks
Hayward super pump erratic
Is the bump handle very loose up and down? if it is then your tube sheet inside is broken allowing water to freely bypass filtration unit. would need more info. filter model. ec
Apr 12, 2013 | Pool & Spa
What causes erratic idling on a peugeot 107
i had the same problem with my pevgeot. its the rev counter getting stuck on and/or sticking xx
Mar 14, 2013 | Peugeot Cars & Trucks
I have an 02 wrangler and the oil preasure goes down when Idling is that an oil pump going bad?
First we would need to know when this occurs. Asuming the oil level is at the full mark!. If the pressure goes up during acceleration and down at idle when engine is fully warmed up, then this is normal. An engine requires 10 psi of oil pressure per 1,000 rpm ( ex. 20 psi at 2,000 rpm, 25 psi at 2,500 rpm, and so on ) . If the gauge is moving back and forth erratically at idle , i would say the gauge is bad. If it drops to 0 while accelerating I would say your oil pump is bad. If from time to time it seems to work and other times it seems not to work, I would say the oil pressure sending unit for the gauge is bad. If the pump failed you would start to here a Knocking noise from the engine in a short period of time. Use the above scenario's to narrow down what it may be.
Oct 16, 2010 | 2002 Jeep Wrangler
My 1998 Toyota Camry also has an erratic speedometer which jumps down to a lower or zero mph which after a couple of seconds causes the transmission to downshift and the engine to rev. Diagnostics have...
Check all the wiring from the vehicle speed sensor (VSS) to the ECM, including all connectors. It seems that there may be an intermittent open (or short) causing the ECM to sense the vehicle slowing down/stopping.
Sep 27, 2017 | 1994 Toyota Corolla
Oil pump is going bad in my 1999 chevy lumina
Jul 02, 2010 | 1999 Chevrolet Lumina
The oil pressure gauge goes from 0 to all the way up and the needle moves back and forth while driving it checked oil its good now its clicking underneath the car and it felt like the transmission was...
Mar 27, 2010 | 2005 Nissan Altima
Oil pressure gauge reads normal when first starts. as it warms up, gauge goes to zero. If I rev engine, gauge goes back to normal.
Two things...when it reads zero, is there any engine noise (tapping or knocking)? After you rev the engine does the pressure read normal at idle and function normally, or does it go back down? Either way, you should not drive the vehicle 'till you have a mechanical gauge (yours is electro-mechanical) put on there and the actual pressure is tested. The condition may be a bad sending unit, a bad bearing or possible obstructed oil pump screen. The repair is obviously different for each one and the price is as well.
Oct 20, 2009 | 2002 Jeep Grand Cherokee
Charge airconditioning for saturn 2001
to just charge the system if it is low, then just buy a recharge kit with a pressure guage built into it. They are very common. I would buy the one with the dye and a dye detection light. Either way when you do this it goes in the low pressure side. fill it till it is to the correct pressure and the guage has pictures to show you how much to put in. The one with the dye will tell you if you have a leak and where it is. If you need to completely redo the entire system right back and tell me, but you will need more instructions.
Jun 21, 2009 | 2002 Saturn L-Series
Idle irratic
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Apr 11, 2009 | 2001 Chrysler PT Cruiser
Garden Logo
171 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
