Question about Dirt Devil CV950 Central System Vacuum
Every time we plug in the vaccum hose into the wall recepticle the vaacuum turns on for half a second and then blows the circuit breaker. This just started a few days ago. We tried replacing the 20 am
Every time we plug in the vaccum hose into the wall recepticle the vaacuum turns on for half a second and then blows the circuit breaker. This just started a few days ago. We tried replacing the 20 amp circuit breaker but it doesn't help. When we push the reset button on the unit it buzzes loud for a split second and then goes silent. After this nothing happens when we plug in the vacuum into the recepticle.
3 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: My vacuum is making a horrible noise!
This model by Dirt Devil is notoriously noisy anyway. Flip the model over on its side and check the floor plate where the brush is spinning; undo the screws and check the condition of your drive belt. The Dynamite and the Quick Vibe uprights are both very noisy - I couldnt wait to get rid of both of mine!
Posted on Nov 16, 2007
  • 8 Answers
SOURCE: over heats and shuts off, wont start again untill
This unit need disassembly and internal cleansing. Yep, it's dirty inside. The motor probably is dirty also and should be blown out with an air compressor.
Posted on Nov 10, 2009
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
I have a George vacuum and it's died. I have
Of course, you should double check the plug-in recepticle - just to be sure you have not thrown a house breaker. The easiest way is to simply plug something else into the same recepticle. If you simply move the vac plug, you may choose another recepticle oparating on the same breaker.
How did you check the fuse? Fuses can fool you. As a general repair tech, I learned long ago not to rely on my eyes. I have a multimeter and do an ohm check - because sometimes a fuse can look ok, but actually be burned in-two where its not easy to see.
All that ruled out, the most common thing that stops functioning when a vac dies is the switch.
Don
That ruled out, when vacs die it usually the switch.
Apr 06, 2012 | Vacuums
My BROAN CV-110 hose with the rug beater only works if I turn it on from the base unit. Shouldn't it turn on when I plug the hose into the wall recepticle? Do I need to replace the hardware at the end of...
In order to do this right you need to get in touch with the Broan Company. This could be difficult to do.You can get a VAC repair man that could answer you as well. They could even have parts for your machine.
Nov 05, 2017 | Vacuums
Was vacuuming with no problem and the vaccum just shut off. . .what can I do?
Check that the electrical cord if fully inserted in the
wall outlet. See if the vac has a circuit breaker switch
on the electrical plug called a GCFI,or on the vac itself,which probably has tripped. Good luck.
Apr 01, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
Brush does not turn on my vaccum
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Jan 20, 2008 | Vacuums
Central vaccum
If the outlets work on the 2nd story ok, and not on the 1st floor, then you may have a wire that has come loose. There maybe a junction that split off between the 1st and 2nd floor. I assume you are talking about the suction and not the brush roll on the power head. If it is the power head not working, then check where the 2 prongs go into the outlets to make sure that the plug receptacle haven't gotten pushed in from the holder.
May 30, 2007 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil CV950 Central System Vacuum Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
