Question about Tripp Lite Internet 750U (internet750u) UPS System
UPS burned 4 internal components while idling
While it was idling during my vacation the UPS had a burnout: a pair of 1N5404 power diodes (they split open and scorched the board), an IRFZ44V power MOSFET (shorted gate to drain), and a circuit trace (melted through). The transformer appears perfect, and the battery remains good.
I replaced components and fixed those faults; the unit turns on and the buzzer sounds momentarily like normal but there's no voltage on the regulated outlets.
If I had a circuit diagram (with voltages marked) I might be able to fix it. Are they available?
Or is there somewhere to send the circuit board for refurb?
Thanks,
Kurt
  • kurtking May 09, 2009
    palaboy, that would have been the second test had it worked plugged in. Right now it's apart. FWIW, before plugging it in, when I connected the battery, there was no spark.
    P.S. Sorry about the double posting - didn't get a completion until the second.
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
M120 will not power up - no lights, nothing
The Geek Squad at Bestbuy can do this. They are rather pricy though.
Jun 26, 2008 | Mirra M-120 (MIRRAPERSONALSERVERM120)
There is persistent low volume humming sound coming through all the speakers when the reciever is on, it is just loud enough to interfere with the audio I'm trying to listen too (especially dialog on the...
You could have done a very slow damage to the Yamaha if your UPS was not a pure sine wave type ( on line UPS ). Most of the UPS we get are called Off line type and are far cheaper than the On line pure sine wave type. The out put of the Off line type UPS is not a sine wave ( the natural waveform of AC voltage ) and strains the Power supply circuit of any device connected to it.
Now if the humming sound is the same irrespective of the volume position, it is a power supply problem. You might be having a leaky rectifier diode or capacitor. First change the diodes and see if its ok then change the main filter capacitors too.
Apr 28, 2011 | Yamaha RX-V663 Receiver
Mge ellipse ups 1200 wont turn on/power up
hello, ik got a lot of these UPS for repair. I exclude any battery problem that I suppose you already checked. The Systems I have here does all have problem at charger electronics (VT 9 or components around) mostly burned out (short circuit). No repair is possible as copper lines are burned.
Apr 05, 2011 | MGE UPS Pulsar Ellipse 1200 UPS System
Its not starts properly,my batteries are in good condition
Normally if this UPS is in working condition and the batteries are also good, you should be able to start the UPS by just using the battery cabinet. As soon as power is applied the fan must run and the 4 yellow led for battery/load should lit up. If it is completely dead, then a qualified technician will have to check the internal circuit. It has one main board on which all power components are mounted and a separate control board. Generally there is a 80/100 A than goes opened. I hope you can give us more information if the UPS is completely dead or the led comes up
Feb 21, 2011 | MGE Comet EXtreme 12kVA (891012-21) UPS...
Burning smell came out from the device.
Shutdown the equipment connected to the UPS, disconnect the load and remove the main power to the UPS. Open the UPS to see if you can see any sign of burning component. Confrim that the UPS is not Overloaded before the shutdown. If you are not an experienced techinician with UPS please contact an experience Technician because there are life Voltages in the UPS which can cause electric shocks.
Jun 17, 2010 | Computers & Internet
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
How to solve single phase lost in UPS at input end
What size UPS and make and model?
First make sure your utility is reaching the UPS and it's not on that end, sounds like the problem might be with your input power not the UPS.
If power is getting to the unit, you may have a failed power component internally, such as a fuse or transistor.
Nov 05, 2009 | Zenith ZTG Nema-3R, 400 Amps Three Phase,...
Timer
firstly check your sleeping timer set ups. if that is okey, then check the following
the power supply components eg
power transistor on the power supply lekage
zener diodes, power diodes of the bridge rectifier.
in short the supply is drowing to much current, hence semiconductors are heating up and reach a cutoff point, and saturates
Mar 29, 2009 | Toshiba 35A44 35" TV
Tripp Lite Internet 750U (internet750u) UPS System Logo
224 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
