Question about Neff B1421 Electric Single Oven
Hello could you tell me were i can get the glass front door from for a neff b142wogb/01
    Sergeant:
  • 228 Answers
Yes you need to go online to bosch website and look for quickfinder this is the tool used to locate spares, the site is for bosch neff seimens as they are all one company put in your enr number or model number and you will get an exploded diagram of your oven you can then find part number.
I looked and it appears to be 297595 in brown or 297601 in white retails at £61.03 ex vat
HOPE THIS HELPS.
Posted on Jul 20, 2009
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Neff t2766n0/01 FD 8307/0895 diagram
Google "Neff service agent" in your local area
Oct 13, 2013 | Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
How do I sepate the inside from the outside of a neff oven Bl641 door
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Feb 18, 2012 | Neff B1641 Single circotherm super...
My outer glass on door has shatter by its self can it be replace
You should be able to obtain a replacement door glas, they are usually supplied as a seperate item.
Try the following.
WWW.ESPARES.CO.UK/NEFF
WWW.NEFF.CO.UK/CONTACT.HTML
Mar 07, 2010 | Neff B1421 Electric Single Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Neff B1421 Electric Single Oven Logo
246 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
