AIR CONDITIONING RECHARGE
WHERE IS THE RECHARGE PORT ON A 1999 FORD EXPEDITION?
  • 1,150 Answers
Http://www.autozone.com/autozone/ymme/ymmeYear.jsp?_requestid=171996
Go to this web site. Since you did not have enough specifics, you and navigate this web site and find most everything you need about your vehicle.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
Where Is The Air Conditioning Recharge Valve (low side port) located on a 1999 Ford F-150?
The caps are generally different sizes, the recharge hose from the can, will only snap on to the correct one.
Sep 24, 2017 | Ford F-150 Cars & Trucks
Trying to find air conditioning recharge port (low side) on 2000 Expedition
I have run into this same problem. Try looking on the passenger side underneath the hood. It is usually on the line at the back of the engine behind the drier (accumulator). You really have to look but the little rascal is there.. "Its in the dark place" as my dad used to say.. Best of Luck
Aug 20, 2011 | 2000 Ford Expedition
WHEN I SPEED MORE 70 MPH THE AC STARTS BLOWING HOT AIR FOR 10 SEC0NDS END THEN GO BACK TO COOL AIR.
Sounds like a leak in the Compresser lines and you lost some freeon.You need to have somone service the air conditioning system.Ford also has cutout switches on compresser on some models so when you call for full throttle it shuts off air momentarily so you have full power to pass someone.See if you truck has this switch.More than likly you need a system recharge.
Apr 12, 2011 | 1999 Ford Expedition
I need to know where the recharge port is to recharge A/C on a 1999 Ford Expedition
Your A/C system will have two service ports, there isn't any "recharge" ports. You add refrigerant to the LOW side only. Prior to adding any refrigerant, you need to check the system pressures with a manifold gauge set. If the system has enough charge and there is another issue, adding refrigerant can make for worse problems. Automotive A/C is best left to the right person with the proper equipment to service them. If you follow the lines from the compressor, the LOW side will be the smaller diameter of the two service ports.
Mar 31, 2011 | 1999 Ford Expedition
I am looking for the low port for the air condition unit to do a recharge of the freeon
its on the larger ac line thats the low pressure side between the compressor and the firewall hope this helps
Jul 26, 2010 | 1997 Ford Expedition
Where is the ac recharge port for a 2002 expedition
one on left side by radiator other one on accumalater by cab
Jun 20, 2010 | 1999 Ford Expedition
Cant find Where air conditioner recharge port is for 1999 ford expedition
Did you look on the compressor for the low side port??
May 06, 2010 | 1999 Ford Expedition
Cant find AC charger in a 1999 frod expedition. V8
look for the large ac line/hose coming from the ac compressor and follow it untill u come to the ac service port , it is the small port.
Jul 05, 2009 | 1999 Ford Expedition
My 1999 Ford Expedition Eddie Bauer is having air conditioning problems is this common?
what kind of problem?, the most common is hot air and compressor is running, but hot or warm dash outlet air.
Jun 28, 2009 | 1999 Ford Expedition
Heating & Cooling Logo
213 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
