Question about Mitsubishi WS-55859 55" Rear Projection Television
TV was on and working,suddenly the remote would not command the tv, then the manual buttons would not command it either. Now the tv does not turn on. the green light blinks for a minute then goes off.this is a ws-65511 1080 hd
  • 1 more comment
  • boogsneva May 09, 2009
    I'm trying to avoid the cost of a technition. My tv was working,remote quit commanding the tv then the manual buttons would not command the tv or even turn it on. Blinking green light for about 30 seconds then nothing.
    I have a Mitsubishi WS-65511 1080 HD Tv. It quit taking commands from the remote, The manual buttons don't command the TV > I'm just getting the green flashing light for 20-30 seconds and nothing else.One expert said I needed to replace my inverter board and directed me to an online store where I was told none available. Does my modle even have an inverter board. Is this advise valid?
  • 6,784 Answers
Hi, this unit dose not have an inverter board at all. you have many issues here that will require you to replace the main board, control board and, power as well. this repair will be costly. It seems that the original issue was the control board but, it has cascaded to the main and power Assembly as well. i will list all parts needed and there respective locations as well below.(Front board needed also)
PWB-Main-930B866012----$312.95
PWB-Power-930B879002---$381.95
Control-2-
935D587002---$72.95
Front board -
935D588003--$72.95
Replacing all these circut boards will fix this unit.
Total repair Cost is $840.00.
All parts can be ordered at the site provided below.
www.partstore.com (1-866-925-PART)
Posted on May 09, 2009
    President:
  • 2,923 Answers
You need to replace the inverter board of your TV. This is a common issue with LCD TV. Here, I provided you the link where you can see the inverter boards:
http://www.shopjimmy.com/catalogsearch/result/index/?q=INVERTER+BOARDS&stock=all
Have a great day!
  • 413 Answers
Kindly try loosing the static by disconnecting from ac after wards push power button for 20 seconds
now connect to ac and start it if things are fine it will work else it means you have to take it to either local technician or contact the manufacturer
  • shankar anand jha
    shankar anand jha May 09, 2009
    yes sir this is a valid advise as television today has got onbaord inverter and power modulator
    that has to be taken care of
How do I get my att&t u-verse remote control to recognize my 51 inch samsung TV?
The remote can't recognize the tv, it doesn't have that capability. If you want to use it to command that tv you must program it accordingly. Basically you must introduce the code that corresponds to the set of commands that your tv uses - if they are present in the remote.
This is the programming procedure:
1 - hold down the TV button on the Uverse remote. As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
2 - Find the 4 digit code for your device in the User guide that was given you when the Uverse was set up, or online at
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
3 - At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. If it turns off then turn it on with the remote and test the other buttons. If they don't work then try a new code.There are a lot of codes for Samsung in there, try them all until you find the one that has the best compatibility - most buttons that can be used.
4 - If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter to memorize it. This generic code will provide just a basic control, if you really need full control then you will need another remote.
Jul 02, 2011 | Televison & Video
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Programming the remote to my tv do not no the tv code
The code can either be automatically found or you can look it up online. To automatically program it follow these steps:
Turn on the TV, and then point the remote control toward the TV. Then press and hold the TV button and the OK button at the same time for two seconds. Then all of the buttons will light up for two seconds, then only numbers 1-12 will stay lit.
Then press the CH+ button to send a series of off commands to your TV. Continue pressing until your TV turns off.
Note
Give enough time for the TV to respond to the off command after you press each button. Some TVs take more time to react to off commands than other TVs.
Press the TV button to save the code and to exit. All the buttons on the remote control will blink three times to confirm the code.
If this does not work then repeat the steps up to the point where the 1-12 buttons light up. Then go to this site and find your TVs code, there will most likely be a few codes for your TV, try each one until one works:
http://www.maxconsole.net/forums/archive/index.php/t-13852.html
After you enter the code, press CH+ again until your TV turns off.
That's it, you shouldn't have a problem anymore. Good luck.
Feb 13, 2010 | Microsoft Xbox 360 Universal Media Remote
I need instructions for the zenith universal remote 3201 for a new Panasonic LCD TV
If you have a manual for remote and you try all codes for your model and it didn't work, you may try for automatic search. First turn on TV, and point the remote toward the TV. You press: SETUP and hold, and press button for device: TV, lite is on, then you release all button and press again SETUP, just once, the lite is blinking, now press the power button on a few seconds. When your tv is turned off, you press button TV. Press button for power and it will turn on your tv. Try other commands on your remote, if everything is working that's it, if not do procedure again. Hope this was helpful, if not, ask more. By!!!
Nov 03, 2009 | Zenith ZN-501S Remote Control
Deactivating tv remote control codes
I am not certain these are the instructions for your specific remote. If you are brave, give this a try.
To Clear all Learned Commands under a mode
Clearing learned commands is helpful if, for example, you
replace your CD player with another brand or model. If
you had learned a feature from your old CD player’s
original remote on to this remote (such as RANDOM
PLAY), that feature would no longer work for your new
CD player. Should you wish to remove or clear one or
more “learned” commands, follow the steps below:
1. Press and hold the SETUP button until the red
indicator turns on. Release the SETUP button.
2. Press and release the button for the mode you want
to clear (TV, VCR, etc.). The red indicator blinks off.
3. Press and release the LEARN button TWICE. The
4. Press and release the SETUP button. The red
indicator turns off. All learned Commands under that
mode are now cleared.
Master Clear - To Clear all Learned
Commands under all modes
2. Press and release the LEARN button TWICE. The
3. Press and release the SETUP button. The red
indicator turns off. All Learned commands in the
remote are now cleared.
If you would rather error on the side of caution, here is the link to Philips Customer Assistance. It will help you locate the correct model number and the appropriate User Manual.
http://www.support.philips.com/support/html/index_us_en.html
I hope this helps, good luck!
Kym McC
Oct 05, 2008 | Philips Magnavox Learning Universal Remote
Remote not working, TV won't turn on.
Some TV sets have a vacation switch in the rear of the set. This is to allow it to be in standby but not turn on. Check for this feature if your set has it, and it is turned on.
If the set has failed:
It sounds like something in the TV failed. Common failures in these sets are the power supply and scan circuits.
Jerry G.
Apr 13, 2008 | Televison & Video
Remote suddenly desn't work
you may have accidentally pressed one of the wrong button at the bottom of the remote control. the codes are in the back of the user manual
Oct 19, 2007 | Philips 50MF231D 50 in. Plasma Television
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
